Old 09-27-2013, 01:04 PM
Bernie@Bimmerfest Bernie@Bimmerfest is offline
Administrator
Mein Auto: 83' 323is, 07' MINI JCW+
Major recall for 2012-14 F30 BMW 3 Series with N20/N26 for dangerous loss of braking
BMW recalls 3 series 5 series X1 X5 Z4 with N20 or N26 engine
Delivery of N20 and N26 powered vehicles stopped as a result of power brake assist problem
On September 26th, BMW of North America announced to NHTSA its intention to conduct a voluntary Recall on certain 2012-2014 model year BMW 3 Series, 5 Series, X1, X3 and Z4 models equipped with the N20 or N26 engine, produced from May 2012 to August 2013.
Affected vehicles in dealer inventories will not be sold or delivered to customers until the recall repair has been performed. Vehicles at BMW vehicle delivery centers will be corrected before shipment to dealerships.
The Problem:
The oil supply from the intake camshaft to the brake vacuum pump can become restricted. If this happens the brake vacuum pump could fail due to lack of lubrication, resulting in a loss of power brake assist.
The hydraulic brakes will still function to stop the vehicle but without power assist. Without assist the driver will need to apply much greater pedal pressure to stop the vehicle. The distance required to stop the vehicle will increase as most drivers will not be able to apply enough brake pedal pressure.
In the event of a loss of brake power assist pull the emergency brake and apply as much brake pedal pressure as possible. If your BMW has an electronic parking brake pull up and hold the switch to engage the brake.
Move away from traffic and park in a safe location as soon as possible. Contact BMW Roadside Assistance and have your vehicle taken to the nearest BMW dealer.
Solution and Repair
A repair solution for vehicles already on the road is under development and not available at this time. Existing owners will be notified of the recall in November by letter and again in December by letter when parts are available. Wait to receive your notification letter before contacting your dealership for service. The repair letter will be sent when the dealership has the necessary parts, tools and procedures to preform the repair.
The solution involves inserting a locking ring onto the camshaft so the oil supply to the brake assist vacuum pump is not impaired. The repair will take approximately two hours but can vary depending on your BMW dealers schedule. The repair will be preformed free of charge.
Affected Models
  • 2012-14 320i/328i, 320i/328i xDrive Sedan manufactured between May 2012 August 2013
  • 2014 328i xDrive Sports Wagon manufactured between March 2013 May 2013
  • 2012-13 528i, 528i xDrive Sedan manufactured between June 2012 June 2013
  • 2013-14 X1 sDrive28i, X1 xDrive28i manufactured between June 2012 June 2013
  • 2013-14 X3 xDrive28i manufactured between June 2012 August 2013
  • 2012-14 Z4 sDrive28i manufactured between June 2012 June 2013
Models not list are not affected due to different lubrication and vacuum pump designs.
Number of vehicles affected in the US
Up to 76,190 BMWs are affected by this safety issue. The model break down is as follows -
  • 2012-14 320i/328i, 320i/328i xDrive Sedan - 37,473 potentially affected
  • 2014 328i xDrive Sports Wagon - 176 potentially affected
  • 2012-13 528i, 528i xDrive Sedan - 12,708 potentially affected
  • 2013-14 X1 sDrive28i, X1 xDrive28i - 10,547 potentially affected
  • 2013-14 X3 xDrive28i - 14,517 potentially affected
  • 2012-14 Z4 sDrive28i - 770 potentially affected
Known accidents
BMW is aware of three minor accidents with no confirmed injuries as a result of this problem. The NTSB has 7 reported incidents but that does not mean they have 7 accident reports. Vehicles affected have experienced the failure at low millage. It is not clear if having a higher mileage car means you will not have the failure.
Should you continue to drive your N20/N26 powered BMW
BMW says it is safe to continue to drive your vehicle for now. As soon as you get the service letter that will be coming in December you should have the recall work performed. If you feel a loss of braking power pull to the side of the road and have your BMW towed to the nearest dealer by BMW Roadside Assistance.
Are 4 series deliveries going to be affected
BMW has not commented at this time on the 4 series. Models produced as recently as August are affected so it is possible early production 4 series (production started in July) will be held at the vehicle delivery center until the repair is available. We will continue to follow the 4 series delivery story and provided updated information as it happens.
What to do now
We have no choice but to wait for the letters and more information from BMW. In the mean time everyone be careful out there. There are 7 reported incidences of issues to the NTSB so far. The NTSB estimates that for ever report there are 40+ incidents that are not reported. Has anyone had trouble loss of brake assist in their N20/N26 powered BMW? Does this make anyone nervous to drive their BMW?
Recall Update:
This is a follow-up to the delivery stop announcement of certain N20 and N26-equipped models. Vehicles on the delivery stop VIN list must not be retailed or delivered until the defect has been corrected.
Technical Description
An oil plug in the intake camshaft may become displaced, restricting oil supply to the vacuum pump. Continued operation may lead to failure of the vacuum pump, resulting in loss of power-assist braking. Only camshafts from one supplier exhibit this issue; therefore, not all N20 and N26-equipped vehicles are involved in the delivery stop and Recall.
A repair solution is under development to secure the intake camshaft oil plug, but will not be available before December.
Customer Notification
Owners of vehicles which have already been delivered will receive initial notification in November, informing them of the issue. A second letter will be mailed in December, advising customers to schedule an appointment with your center to have the Recall completed, when parts and the repair procedure become available.
Old 09-27-2013, 01:17 PM
kkapdolee kkapdolee is offline
Mein Auto: a car
Thanks for the post. If BMW were to send me the letter, will it be sent from BMWNA or the dealership I bought my car from? I have two different addresses listed as I had moved since taking delivery.
2013 328i Sedan | ULEV N20 | M Sport Line | Estoril Blue II | Black Dakota Leather | Premium Package |
Technology Package | Driver Assistance Package | Dynamic Handling Package | Lighting Package |
Harmon Kardon Surround Sound | Sport Automatic Transmission with Shift Paddles | Anti Theft Alarm |
Port install: BMW M Performance Exhaust |
Old 09-27-2013, 01:33 PM
328AL's Avatar
328AL 328AL is offline
Mein Auto: 2014 328i on order
Originally Posted by Bernie@Bimmerfest View Post
September 27, 2013
Situation:
The oil supply from the intake camshaft to the brake vacuum pump could become restricted. If this were to occur, the vacuum pump could fail due to lack of lubrication, resulting in a loss of power brake assist.
A repair solution for vehicles already on the road is under development and not available at this time. Existing owners will be informed of the recall in November by letter and again when parts become available.
In the mean time everyone be careful out there. There are 7 reported incidences of issues and the NTSB estimates that for ever report there are 40+ incidents that are not reported. Has anyone had trouble with their BMW? Does this make anyone nervous to drive their N20/N26 powered BMW?
So no sales no leases for now?
Old 09-27-2013, 01:39 PM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Correct.
Old 09-27-2013, 01:45 PM
328AL's Avatar
My car is in transit, how do I figure out if it's impacted? is there a list of VIN numbers?
Old 09-27-2013, 01:46 PM
328AL's Avatar
Originally Posted by tim330i View Post
Correct.
Holly sh*t
Old 09-27-2013, 01:48 PM
tim330i's Avatar
Prob call your dealer. We don't have a list of effected VINs.
Old 09-27-2013, 01:52 PM
PK2348 PK2348 is offline
Mein Auto: 2015 335 xdrive M-Sport
Correct.
Wow, and they have no fix for it currently, so it means all 4 cylinder BMWs are grounded on dealer lots for an indefinite amount of time?
Does it affect 4 series? People waiting for their 428s will not be happy!!!
Old 09-27-2013, 01:54 PM
328AL's Avatar
Isn't N20-N26 used for 1, 3, 4 and 5 series?
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Dayum. This will not end well.
Old 09-27-2013, 01:55 PM
tim330i's Avatar
I should clarify that the effected engine count is not yet known. It could only be engines with parts from certain factories or whatever As it stands we don't know and it could be a ton of cars.
Tim
Old 09-27-2013, 01:56 PM
Tim
Stickie?
Old 09-27-2013, 01:58 PM
it is, except for 1, i think 128 still has N52, also X1, X3, and Z4 have N20/26 i think.
I read it affects vehicles manufactured through august of 2013. Appears September built cars are not part of the recall. When did prroduction start for the 4er?
I wonder how they fixed it in September production?
Old 09-27-2013, 02:01 PM
HugH HugH is offline
Mein Auto: 2015 BMW 535i
If you filed a change of address with your old local Post Office, the mail will be forwarded to whatever address you gave them, free of charge.
You might want to contact BMW directly and rectify the situation.
Old 09-27-2013, 02:06 PM
328AL's Avatar
engines manufactured, not cars
Old 09-27-2013, 02:09 PM
mr_clueless's Avatar
mr_clueless mr_clueless is offline
Mein Auto: 2015 328i M-Sport
What is the source of this article? Is there an external link?
2015 328i / M Sport / Alpine White / Coral Red / 4 DR / 6 MT / Rear Camera + PDC / Xenons / DHP / 55K+ Miles / Bought 10-30-2014
Old 09-27-2013, 02:12 PM
Same here.
This website which is used for checking recalls doesn't seem to be working.
http://www.bmwusa.com/Standard/Conte...er/Recall.aspx
Old 09-27-2013, 02:14 PM
jamesms69 jamesms69 is offline
Mein Auto: 2014 328i Sport Wagon
Wow! I'm glad they have responded relatively quickly to the NHTSA investigation. I'm hoping the -August 2013 is true, as my September production is on the boat, and I could not wait a day longer than I already have to!
Good luck to anyone that is affected.
Old 09-27-2013, 02:18 PM
tim330i's Avatar
4 series production started in July. It is likely the 428s will be held as a result of this. I'm updated the first post with more information.
Old 09-27-2013, 02:25 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
it may be related to engine production date (produced in adv of car production)
we'll need to see the chassis number ranges
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
tturedraider's Avatar
Freedom isn't free!!
I have no doubt BMW is working on this as fast as humanly possible, but it is going to be at least somewhat of a PR nightmare. I imagine this will be a national news headline maker - BMW suspends sales as thousands and thousands of the latest edition of BMW's most popular models recalled for possible brake failure. Oy vey!!
www.bmwcca.org
Old 09-27-2013, 02:33 PM
328AL's Avatar
Originally Posted by mr_clueless View Post
Same here.
I checked it, it says call customer service, I doubt it would be there anyway since it's not formally announced to the public.
Old 09-27-2013, 02:34 PM
328AL's Avatar
I just got a word from my SM, he says, if it's impacted, it should not delay delivery for more than 1 day. I don't think I'm buying that.
capt_slow's Avatar
capt_slow capt_slow is offline
Mein Auto: 2017 328d Sports Wagon
So there's no sales of affected cars, but how does this recall affect orders?
Specifically, how does it affect a dealer's ability to place orders?
I was just about to send in my order today...
2014 328i xDrive: Mineral Grey, Black Sensatec, Lighting Pkg, DHP, Driver Assist Pkg., Nav, Park Assist, ACC, Alarm
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, Driver Assist Pkg, M-Sport Pkg, Premium Pkg, ACC, Side/Top Cameras, Park Assist, Nav, HK
Old 09-27-2013, 02:37 PM
Crom! Crom! is offline
Mein Auto: 2014 328i & 2000 ML320
Ah geez, my 2014 328i finished production on 9/13/2014 and it's already in transit in the mid Atlantic. What should I do? I already paid a 1000 deposit. Should I cancel my order? Can I get my deposit back?
bmw recall
