Old 09-27-2013, 02:09 PM
Bernie@Bimmerfest Bernie@Bimmerfest is offline
Administrator
Mein Auto: 83' 323is, 07' MINI JCW+
Recall for 2012-14 BMW X1 models with N20/N26 engines for loss of brake power
BMW recalls 3 series 5 series X1 X5 Z4 with N20 or N26 engine
Delivery of N20 and N26 powered vehicles stopped as a result of power brake assist problem
On September 26th, BMW of North America announced to NHTSA its intention to conduct a voluntary Recall on certain 2012-2014 model year BMW 3 Series, 5 Series, X1, X3 and Z4 models equipped with the N20 or N26 engine, produced from May 2012 to August 2013.
Affected vehicles in dealer inventories will not be sold or delivered to customers until the recall repair has been performed. Vehicles at BMW vehicle delivery centers will be corrected before shipment to dealerships. Existing owners will be notified of the recall by letter with a solution coming in December.
The Problem:
The oil supply from the intake camshaft to the brake vacuum pump can become restricted. If this happens the brake vacuum pump could fail due to lack of lubrication, resulting in a loss of power brake assist.
The hydraulic brakes will still function to stop the vehicle but without power assist. Without assist the driver will need to apply much greater pedal pressure to stop the vehicle. The distance required to stop the vehicle will increase as most drivers will not be able to apply enough brake pedal pressure.
In the event of a loss of brake power assist pull the emergency brake and apply as much brake pedal pressure as possible. If your BMW has an electronic parking brake pull up and hold the switch to engage the brake.
Move away from traffic and park in a safe location as soon as possible. Contact BMW Roadside Assistance and have your vehicle taken to the nearest BMW dealer.
Solution and Repair
A repair solution for vehicles already on the road is under development and not available at this time. Existing owners will be notified of the recall in November by letter and again in December by letter when parts are available. Wait to receive your notification letter before contacting your dealership for service. The repair letter will be sent when the dealership has the necessary parts, tools and procedures to preform the repair.
The solution involves inserting a locking ring onto the camshaft so the oil supply to the brake assist vacuum pump is not impaired. The repair will take approximately two hours but can vary depending on your BMW dealers schedule. The repair will be preformed free of charge.
Affected Models
  • 2012-14 320i/328i, 320i/328i xDrive Sedan manufactured between May 2012 August 2013
  • 2014 328i xDrive Sports Wagon manufactured between March 2013 May 2013
  • 2012-13 528i, 528i xDrive Sedan manufactured between June 2012 June 2013
  • 2013-14 X1 sDrive28i, X1 xDrive28i manufactured between June 2012 June 2013
  • 2013-14 X3 xDrive28i manufactured between June 2012 August 2013
  • 2012-14 Z4 sDrive28i manufactured between June 2012 June 2013
Models not list are not effected due to different lubrication and vacuum pump designs.
Number of vehicles affected in the US
Up to 76,190 BMWs are affected by this safety issue. The model break down is as follows -
  • 2012-14 320i/328i, 320i/328i xDrive Sedan - 37,473 potentially affected
  • 2014 328i xDrive Sports Wagon - 176 potentially affected
  • 2012-13 528i, 528i xDrive Sedan - 12,708 potentially affected
  • 2013-14 X1 sDrive28i, X1 xDrive28i - 10,547 potentially affected
  • 2013-14 X3 xDrive28i - 14,517 potentially affected
  • 2012-14 Z4 sDrive28i - 770 potentially affected
Known accidents
BMW is aware of three minor accidents with no confirmed injuries as a result of this problem. The NTSB has 7 reported incidents but that does not mean they have 7 accident reports. Vehicles affected have experienced the failure at low millage. It is not clear if having a higher mileage car means you will not have the failure.
Should you continue to drive your N20/N26 powered BMW
BMW says it is safe to continue to drive your vehicle for now. As soon as you get the service letter that will be coming in December you should have the recall work performed. If you feel a loss of braking power pull to the side of the road and have your BMW towed to the nearest dealer by BMW Roadside Assistance.
Are 4 series deliveries going to be affected
BMW has not commented at this time on the 4 series. Models produced as recently as August are affected so it is possible early production 4 series (production started in July) will be held at the vehicle delivery center until the repair is available. We will continue to follow the 4 series delivery story and provided updated information as it happens.
What to do now
We have no choice but to wait for the letters and more information from BMW. In the mean time everyone be careful out there. There are 7 reported incidences of issues to the NTSB so far. The NTSB estimates that for ever report there are 40+ incidents that are not reported. Has anyone had trouble loss of brake assist in their N20/N26 powered BMW? Does this make anyone nervous to drive their BMW?
Recall Update:
This is a follow-up to the delivery stop announcement of certain N20 and N26-equipped models. Vehicles on the delivery stop VIN list must not be retailed or delivered until the defect has been corrected.
Technical Description
An oil plug in the intake camshaft may become displaced, restricting oil supply to the vacuum pump. Continued operation may lead to failure of the vacuum pump, resulting in loss of power-assist braking. Only camshafts from one supplier exhibit this issue; therefore, not all N20 and N26-equipped vehicles are involved in the delivery stop and Recall.
A repair solution is under development to secure the intake camshaft oil plug, but will not be available before December.
Customer Notification
Owners of vehicles which have already been delivered will receive initial notification in November, informing them of the issue. A second letter will be mailed in December, advising customers to schedule an appointment with your center to have the Recall completed, when parts and the repair procedure become available.
Old 10-16-2013, 01:48 PM
Administrator
Vacuum Pump Recall Update
Near the end of September, BMWNA announced its intention to conduct a voluntary recall on certain 2012-14 BMW 3 Series, 5, X1, X3, and Z4 equipped with an N20 or N26 engine, with production from May 2012- August 2013.
Possible loss of brake power assist could occur, due to a lack of oil supply to the brake vacuum pump from the intake camshaft. Brakes would still function, however greater pedal pressure would be required, increasing stopping distance.
A repair was not yet available, but would involve the inserting of a lock ring onto the camshaft, so the pump would not be impaired.
An update has been issued to the previous announcement. A stop delivery of certain N20/26 equipped models, according to vin, has been announced. Only camshafts from a certain supplier exhibit this issue. This means that not all N20/26 equipped vehicles are not involved in this stop delivery and recall.
A repair is currently under development. It will secure the intake camshaft oil plug, but will not be available before December.
Owners of already delivered vehicles will receive notification in November, to inform on the issue. A second notification will be mailed in December, advising customers to schedule an appointment to have the recall completed, when parts and procedure become available.
The original post has also been updated with this information.
Old 10-16-2013, 07:19 PM
imua1 imua1 is offline
Mein Auto: 2014 X1
For those that would develop the problem now or near term before the fix is out, what would happen to their car? Stored and sidelined until the fix is out?
Old 10-16-2013, 07:48 PM
Administrator
I can't say. I've driven older vehicles without power brakes, you would just need to be aware that you may require more stopping distance and pedal input, if the problem were to occur. Personally, I would drive it, probably more careful than usual.
Old 10-19-2013, 05:09 PM
Mein Auto: 2014 X1
BMW recommends not to drive car if brake power asist fails. If the brake defect did happen before the fix comes out, think the prudent thing is for BMW to provide a comprable loaner or rental free of charge? Has anybody in the forum had the power assist problem? If so how was it resolved?
Old 11-23-2013, 06:40 PM
Mein Auto: 2014 X1
Has anybody gotten a letter for your X1 for the power brake vacuum recall problem?
Old 11-24-2013, 06:52 AM
2013x1 2013x1 is offline
Mein Auto: 2014 X3
Not yet
Sharon
2017 X4 28i
2016 Mustang GT
2014 X3 28i - sold, 2013 X1 x28i - sold
2006 Mustang GT Vert - sold
Old 11-24-2013, 11:45 AM
ScottMZ3 ScottMZ3 is offline
Mein Auto: 2014 X1 sDrive28i xLine
I haven't received anything yet. I believe my 2014 X1 has a 07/13 build date...which means it should be part of the recall.
My brakes have been working great though (knock on wood).
Old 11-26-2013, 08:18 AM
mullini mullini is offline
Mullini
Mein Auto: 2013 BMW sDrive 28i X1
No letter here either. sDrive 28. Purchased Nov 2012.
Old 11-26-2013, 08:59 AM
zznalg zznalg is offline
Mein Auto: 2014 X1 35
Our X1 2.8 had a brake failure the day we purchased it, in September. Then it had another one a week later. It seemed to be the issue described in the notice. The car had about 5% stopping power with full force on the brake pedal. The notice came out a few days after we purchased it. Long story short, our (EXCELLENT) dealership exchanged the X1 2.8 for an X1 3.5 with no financial penalty. Of course we had to pay the difference on the more expensive vehicle. Love the 3.5! (Loved the 2.8 as well).
Old 11-28-2013, 06:06 AM
luvmybeemerbike luvmybeemerbike is offline
BMW bike whore
Mein Auto: 2013 BMW X1
Got the first letter yesterday. I have not had a failure nor has my wife who drives the car 99% of the time, hope she never does either.
Old 11-29-2013, 03:05 PM
MotoWPK MotoWPK is offline
Mein Auto: '13 128i vert, '14 X5 35d
Received our recall today ('13 328ix - 10/12 build) and, as noted by others, it indicates parts to effect the recall are not currently available but are expected in 1/14.
The letter states;
"Description Of Repair
The power assist braking system will be inspected and, if necessary, the sealing cap will be secured, which will ensure the brake vacuum pump is lubricated properly."
Is that all there is to this - securing a sealing cap? Is it present but loose in some cases? And, if the pump has not been properly lubricated previously, doesn't the pump need to be replaced as a result of damage that would have occurred due to operating without proper lubrication?
Old 11-29-2013, 03:58 PM
snakelips snakelips is offline
Mein Auto: a car
"Our X1 2.8 had a brake failure the day we purchased it, in September. Then it had another one a week later. It seemed to be the issue described in the notice. The car had about 5% stopping power with full force on the brake pedal. The notice came out a few days after we purchased it. Long story short, our (EXCELLENT) dealership exchanged the X1 2.8 for an X1 3.5 with no financial penalty. Of course we had to pay the difference on the more expensive vehicle. Love the 3.5! (Loved the 2.8 as well)."
There is an unrelated brake issue on the X1 35i's which has to do with the car being abruptly pulled to the right while braking when its raining out. There is a separate thread on that issue.
Old 11-30-2013, 07:43 PM
Mein Auto: 2014 X1
The letter states;
Finally got ours today the last day of Nov. States similarly what is stated above. Bummed that our vehicle was affected. Hope brake vacuum failure does not occur before the fix.
Old 12-01-2013, 04:55 AM
BMW bike whore
Hopefully we will ALL be safe. BMW is trying to downplay this problem by saying a "cap needs to be secured." If it were this simple don't you think it would have been corrected by now? We are now in December, before you know it, we'll be into a new year, lets get cracking with this already. And yes, BMW can crank up 150,000 caps up if that's all that the problem is, something tells me its a bit more involved than they lead us to believe.
Old 12-01-2013, 08:53 AM
Mullini
I got the letter Friday. We have to wait for another letter before we can set up an appointment. I'm not panicking but I understand being concerned. It's the brakes, after all.
Old 12-02-2013, 12:27 PM
Mein Auto: 2014 X1
Does anybody know if this brake assit failure comes all at once or can it be gradual with increasing pressure required over time?
Old 12-02-2013, 01:16 PM
HotRodW HotRodW is offline
Mein Auto: 2013 X1, 2012 Q5
My loss of power assist occurred without any warning. it was a one-time event and hasn't happened since. It scared the p!ss out of me (and likely the driver that nearly T-boned me)! There is a reason it's called a safety recall ... these cars should not be on the road.
Rod
2014 Touareg TDI R Line
2012 Q5 2.0T
2002 RSX
Old 12-02-2013, 03:08 PM
Our two failures occurred with absolutely no warning. After each failure, the brakes performed normally (until the next failure).
So, it was completely unpredictable and sudden. Both failures occurred at very low speeds (5-10 mph) approaching stop signs (on perfect, smooth, dry, warm, clean, unbroken pavement with no gravel nor sand).
Old 12-02-2013, 06:01 PM
skndchanzs skndchanzs is offline
Mein Auto: 2013 X1
Those sound serious and scary. I have not yet received a notice - 2013 sDrive28i began production 8/25/12. Sounds like the notice doesn't do much other than to alert you to what we already know.
DeeDee
Old 12-04-2013, 07:06 PM
Mein Auto: 2014 X1
With supposedly no parts in stock, was your dealer somehow able to get the parts and fix this? If not did the dealer provide a comprable loaner?
Old 12-05-2013, 08:42 AM
No. They bought the car back at the original purchase price. Like I said, they are an excellent dealership!!!!
Old 12-05-2013, 11:46 AM
Mein Auto: 2014 X1
Yes, sounds like an excellent dealership...unfortunately not all of us would be that lucky. In my view BMW corp. has not done a very good job at managing this recall.
Old 12-06-2013, 03:38 PM
kepostil kepostil is offline
Mein Auto: 2013 X1 28I
I have a X1 that falls into the recall, and have yet to receive the notice. Thinking of calling my dealer.
Old 12-08-2013, 08:51 PM
Mein Auto: 2014 X1
Good news it may be that your vehicle was not affected. Bad news is it may be have not been managed correctly.
Has anyone had the repair actually done?
bmw vacuum pump recall
