Old 09-27-2013, 07:14 PM
XjohnnyX XjohnnyX is offline
Mein Auto: 2008 335xi
Question Got JB4 w/stock....What's the next mod?
I'm looking for opinions on my next mod. I've got a 2008 335xi w/33k miles stock with the JB4. What is the next best mod in terms of value and performance?
Johnny
Old 09-27-2013, 09:12 PM
Mein Auto: '06 AW 330xi
Downpipes.
Keep stock intake and add drop in filter.
Intercooler.
Charge pipe.
Meth injection.
E85.
Not in any particular order but I would start with DP though.
Old 09-27-2013, 09:16 PM
Kool... So any suggestions on brands of DPs. Seen quite a few and trying to get up to speed.
J
Old 09-27-2013, 09:41 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Limited slip differential makes a huge diff. Recommend your next mod - check Wavetrac.
One thing leads to another! You'll quickly become dissatisfied with your suspension.....much improvement beyond LSD available.
__________________________________________________ _________
Did I say that? Once again I didn't notice 'x' in your badge....
Old 09-29-2013, 01:33 PM
CAL... If you were to suggest an upgrade..... Assuming I want to get the best value/$$$ spent... Would it be the LSD or DP's or something else?
Johnny
Old 09-29-2013, 04:24 PM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
FMIC should be next. You can get into the very high 11/low 12 range on all stock parts with the JB4/ISO if you go with the BMS back end flash added to your JB4. No matter what you do you will need to cool the intake charge. Expect you are out of warranty so DP's should not be a problem unless you have a strict emissions testing program in IL. Don't know how you will use the car but be aware DP's smell.
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 09-29-2013, 06:48 PM
Well, I'm not really familiar with the nitty gritty of xdrive - have not heard of LSD's installed there. Some discussion re: coilovers but again, it's a diff beast than 335i.
After JB4 install, recommend you get to know it. Lots to explore - you can configure it any way you like in the user config'd map. That'll keep you busy for months!
One thing though: Deep six run-flats for Michelin PSS....
Old 09-29-2013, 06:54 PM
Also, Winter's comin'. Consider a premium all-season like Conti DWS - you really, REALLY don't want Summer performance tires when <50 deg F.
And in snow? Don't. Just don't.
www.Tirerack.com
