Old 09-29-2013, 10:37 AM
M34Lnch M34Lnch is offline
****ie Member
Mein Auto: 2017 BMW 440i
Anyone notice that the 428i only gets 1 mpg better in the city compared to the 435i?
Good news for 435i owners, how did they achieve this?
Old 10-03-2013, 09:05 AM
****ie Member
bump
Old 10-03-2013, 09:31 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK
Is it good news for the 435 or bad news for the 428? N4S
Old 10-03-2013, 09:38 AM
****ie Member
At first I thought it had something to do with the new 8-speed transmissions, but now i think it is likely related to the engine auto start/stop function?
Old 10-03-2013, 10:22 AM
Heybuzzz Heybuzzz is offline
Mein Auto: A4
Yeah, but using that theory the 428 would be higher then it is.
Old 11-16-2013, 07:27 AM
****ie Member
bump
Old 11-16-2013, 08:26 AM
Michael Schott Michael Schott is offline
Moderator
Mein Auto: 2017 VW GTI Sport MT
Why do you keep bumping this thread?
Old 11-16-2013, 09:08 AM
****ie Member
Because I don't have an answer to my original question.
Old 11-16-2013, 09:38 AM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
Probably just physics. The 4cyl is working harder than the I6 in the city cycle, decreasing it's efficiency. It would normally make up for lost ground during idle time, but ASS takes that advantage away.
Current Stable: 2014 335i M-Sport // 2012 X5 35i Premium // 2002 330i Sport
Out to Pasture: 2002 X5 3.0i // 1995 325i Sport
Old 11-16-2013, 02:12 PM
BentZero's Avatar
BentZero BentZero is offline
Mein Auto: M235i
Re: Anyone notice that the 428i only gets 1 mpg better in the city compared to the 43
Yes
Old 11-16-2013, 02:53 PM
bighorns's Avatar
bighorns bighorns is offline
Evil cider brewer
Mein Auto: E92 335i M Sport
Originally Posted by chiefneil View Post
probably just physics. The 4cyl is working harder than the i6 in the city cycle, decreasing it's efficiency. It would normally make up for lost ground during idle time, but ass takes that advantage away.
this. ^^
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=325723&dateline=1371746393
*NEW* delete pls 1K
3K
11K
Old 11-16-2013, 06:43 PM
Moderator
There is no easy answer. My guess is that the EPA test cycle is not like real life and that in reality the I4 is much more efficient. I also disagree that the I4 works harder than the I6 as said above. It's doing the same amount of work with 2 less cylinders that are basically the same size as those in the N52. It only makes sense that using 4 equal size cylinders to do the job of 6 uses in theory 33% less fuel. It only works hard when you put your foot into it and spool up the turbos. These 4 cylinders are not turning at higher RPM than those of the I6 and in fact make more power at lower RPM.
I can tell you that my N20 with 1400 miles on it is averaging an indicated 26.1 mpg in city/local highway driving averaging 31 mph. My N52 averaged about 23 mpg at that average speed.
Old 11-16-2013, 08:23 PM
chiefneil's Avatar
My glib answer of "physics" assumed some grounding in physics, so I apologize for not being more clear.
Your statement "It only makes sense that using 4 equal size cylinders to do the job of 6 uses in theory 33% less fuel" only makes sense if you discount the element of time. If you said, "A 4 cylinder could do the work of 6 with 33% less fuel if it were given 33% more time to do the work", then that's a statement I could agree with in principle. However when both engines have to perform the same work in the same amount of time, you can't expect a 33% advantage.
Since the N20 and N55 share the same basic architecture it makes for a pretty simple conversation - to accelerate at the same rate the N20 must rev higher. Both the N20 and N55 are doing the same amount of work when accelerating at the same rate, however the N20 is revving higher. Yes the N55 has to push more pistons, but the N20 has to rev a bit more; obviously in the EPA test these different approaches to performing the same work offset each other pretty closely. YMMV in the real world as you mention, especially for drivers that accelerate slowly.
Where I would expect the N20 to be more efficient is steady-state cruising at moderate rpm. In that case the superior torque of the N55 is not needed and the additional reciprocating mass, etc of the N55 takes its toll. And indeed this is borne out by the 328i's superior highway mpg rating. In theory I'd expect this to break down at higher speeds as wind resistance increases the need for torque, so at some point the N20 would start revving higher than the N55.
Old 11-16-2013, 08:52 PM
beden1's Avatar
beden1 beden1 is offline
Mein Auto: '11 E93 335is & '08 535xi
Great answer.
Current Stablemates:
'12 Porsche 911 GTS Cabriolet (MT); '11 BMW E93 335is (DCT); '08 BMW E60 535xi
Favorite Cars Gone But Not Forgotten:
'09 Corvette ZO6; '04 MB S600; '01 BMW 740iL; '01 Corvette; '90 Nissan 300ZX 2+2; '89 Jeep Grand Wagoneer; '79 BMW 320i; '79 MB 300D; '71 Pontiac Firebird Formula 400; '67 MG Midget
Old 11-16-2013, 09:23 PM
bighorns's Avatar
Evil cider brewer
"......Where I would expect the N20 to be more efficient is steady-state cruising at moderate rpm. In that case the superior torque of the N55 is not needed and the additional reciprocating mass, etc of the N55 takes its toll. And indeed this is borne out by the 328i's superior highway mpg rating. In theory I'd expect this to break down at higher speeds as wind resistance increases the need for torque, so at some point the N20 would start revving higher than the N55."
Totally agree with this simply based on the cylinder shutdown technology used by some manufacturers to get higher hwy. MPG from larger engines! It has been proven!
*NEW* delete pls 1K
3K
11K
Old 11-16-2013, 09:35 PM
BentZero's Avatar
Mein Auto: M235i
Does the N55 not turn off half of its cylinders while cruising? I just assumed that that was pretty much standard on all 6 cylinder cars these days.
Old 11-16-2013, 09:40 PM
bighorns's Avatar
Evil cider brewer
No. I was pointing out that based on cylinder shutdown technology it has been proven that once a vehicle reaches cruising speed, a 3 or 4 cylinder engine will get better gas mileage than a 6 or 8 because it takes much less torque/horsepower to maintain speed, therefore the extra cylinders are just burning more fuel.
*NEW* delete pls 1K
3K
11K
Old 11-17-2013, 03:56 AM
Moderator
Thanks. I guess that an N20 to N55 comparison is difficult to begin with as one is rated at 240 HP and the other 300 so the added displacement automatically means the N55 makes power more easily but then again the N20 is not as fast which makes sense. It can never work as hard as the N55 because of the smaller displacement.
The reason the F30 N55 gets better mileage than the E90 N55 is a better question and is entirely related to the new ZF 8AT.
In regards to the original question by the OP which I've strayed from, I believe that the EPA test cycle benefits the 335 but everyday driving benefits the N20 and as I mentioned above, I see a significant decrease in consumption between my E90 N52 MT and my F30 N20 MT.
Old 11-17-2013, 04:52 AM
Leslierc's Avatar
Leslierc Leslierc is offline
Sejanus
Mein Auto: From BMWs to Porsches
Yo, Mr. White...science!
Currently: 2015 Porsche 911 GTS and 2016 Cayenne S eHybrid
Past BMWs: `05 645CiC; `07 650i; `08 M6 convertible; '08 135i; `11 750ix MSport; `15 M235i convertible
Others: '11 Panamera 4S; '13 Boxster S; '13 911 C4
"You think that's air you're breathing now?"
-Morpheus
Old 11-17-2013, 04:34 PM
Kayani_1 Kayani_1 is offline
Account closed at users request
Mein Auto: Graphite & Silver E92/E60
At no point does the N20 make more horse power or torque then a inline-6 N55 or N54. Even at 1300 rpm the N55 is making close to 175 lb-ft of rear wheel torque and N20 is merely making 130 lb-ft of rear wheel torque. By the time rpms rise to 2500 rpm the N55 is making close to 270 lb-ft of rear wheel torque and N20 is merely at 225 lb-ft of rear wheel torque.
[/quote]
Old 11-17-2013, 06:23 PM
Moderator
[/QUOTE]
Sorry for not being clear. I was referring to the N52 in that post.
Old 11-17-2013, 10:18 PM
tturedraider's Avatar
Freedom isn't free!!
Which fits the EPA test cycle. The EPA test is performed with virtually perfect precision from vehicle to vehicle, including the same rate of acceleration during each phase of the test no matter what size motor or vehicle. Test drivers are trained and experienced and they follow a precise driving pattern that is projected onto a screen in front of them.
www.bmwcca.org
Old 11-18-2013, 07:32 AM
Jamesonsviggen Jamesonsviggen is offline
Mein Auto: '98 M E36/7:'06 Saab 9-5
There are times when the N20 exploits the smaller displacement and then times it gives up any advantage to the N55 due to utilizing twice the boost.
This is all largely dependent on driving style.
When trying to test absolute economy, 75-80mph, a few traffic lights, a minute of stop and go, I got 39.9mpg out of my 6mt N20 and 35.5mpg out of an 8spd N55. Now had I flogged both cars the gap may have shrunken a fair bit. But on the easy driving, had the N55 been a 6mt, the gap would have worsened. So your driving style dictates that gap.
E36/7: Dinan/RMS stage 2+ blower@11-16lbs of BOOST! 18" BBS LM's, too much more to list
F30: 6mt, SOLD
'06 Saab 9-5 wagon 5mt LSD, clipped turbo, 19psi, 400ft lbs of tq
Old 11-18-2013, 01:23 PM
bighorns's Avatar
Evil cider brewer
All of these comparisons remind me of when "Top Gear" did a gas mileage comparison between a Prius and an M3. For those who have never seen it, they drove the Prius around the track as hard as they could, and all the M3 driver had to do was keep up. The M3 won! (More fuel efficient!)
*NEW* delete pls 1K
3K
11K
Old 11-18-2013, 03:30 PM
sam1983 sam1983 is offline
Mein Auto: BMW 550i
+1
One of the best TG episodes I've seen
Current: 2013 BMW 550i Sport
Former: 2014 BMW 435i Sport
