Old 09-29-2013, 06:35 PM
houston houston is offline
Ericlee
Mein Auto: BMW 525
Auto Window Not Working
My rear right side auto-window is not working. it is currently closed. when I push open button, I can hear two click sounds, but window will not go down. I removed the panel, and it seems all cables are in right positions, not jumping. Please help, what may be the problem?
Eric
Old 09-29-2013, 10:12 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
See my answer in your duplicate thread ...
Originally Posted by houston View Post
My right side rear auto window does not work all of a sudden. When I push switch, I can hear two click sounds, then nothing happens. Is it motor problem, or regulator problem?
Thank you!
These may help...
- BMW E39 rear window regulator replacement DIY (1) (2) (3) (4) (5) (6) & McGyver fixes on the road (1) (2) & rear window regulator repair kits (1) (2) (3) (4) & what brand rear window regulators should I get (1) & where to get salvaged parts (1) & how to remove the rear window (1) (2) & how to adjust the windows after the repair (1) (2) (3) & how to temporarily keep the window up (1)
Old 10-15-2013, 02:49 PM
Ericlee
Mein Auto: BMW 525
Hi, my car is 2003 525i with a 1-piece window regulator on rear-right side window. The window is in fully up position. when I push down button, I can hear two clicks, but window will not come down. How can I get the glass down to remove upper bolt of the regulator?
Old 10-15-2013, 03:40 PM
scottjoh scottjoh is offline
Mein Auto: 1999 323i
The window regulator may not be bad. Do you get the same result when you use the front window switch, rear window switch and when you use the key in the driver's door lock turned to unlock and held for 15 seconds? If the result is the same then the problem could be the general module which controls the rear windows.
Old 10-15-2013, 04:49 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
[QUOTE=bluebee;7866578]See my answer in your duplicate thread ...
My next door neighbor sneezed this morning when she want out to get her paper; do you think she has a cold, or just the flu?
It may be allergies.
Old 10-15-2013, 07:40 PM
Ericlee
Mein Auto: BMW 525
Hi, Scott, Thanks for the response. all other windows work fine. I got the same results with the key in the driver's door lock and turned to unlock and held for 15 seconds. where is the general module that control the rear windows? is it the control panel on the drivers door?
Old 10-15-2013, 07:48 PM
MAICODOUG MAICODOUG is offline
Mein Auto: 530i
Yo Whitney,
Do you get the same result when you use the front window switch, rear window switch and when you use the key in the driver's door lock turned to unlock and held for 15 seconds? REAR SWITCH works or not?
Old 10-15-2013, 08:10 PM
Ericlee
Mein Auto: BMW 525
I swapped the two rear window switches and I got the same results, so both switches are good. same results with using driver side switch to control the rear-right side window.
I also checked the voltage at the motor of bad regulator, and I got 12 vots. So I think it is the motor problem, although I can hear two clicks when push the switch.
Old 10-20-2013, 10:46 AM
Ericlee
Mein Auto: BMW 525
can anyone help me on how to lower the window so I can remove the upper screw of the regulator behind the glass. it stuck on up position, and I have 12 v at motor. I think the problem is motor, cable is in right position.
thanks
