Old 09-30-2013, 09:01 AM
doak35 doak35 is offline
Mein Auto: E90 sedan (2008 328i)
two E90 detailing questions
Hi all... two questions if anyone has had these issues and how they fixed them:
The passenger door handle material is flaking. I'm not sure if it can be recovered, replaced, or what.
The plastic part window trim is discoloring, I'm not sure if it can be cleaned or if it needs to be refinished / replaced (if so, how?)
Old 09-30-2013, 09:49 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
1) Some of those interior trim pieces are easily and cheaply replaceable. I'm not sure if that specific piece is sold individually though. Another option would be to lightly sand the entire rubbery coating off and leave the raw plastic below.
2) Those trim pieces are removable. As an alternative, you could treat yourself and go down the shadowline route and wrap those and the window trim in glossy vinyl for less than the OE parts.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, backline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 09-30-2013, 09:54 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
See if you can locate the parts on realoem.com
Old 09-30-2013, 09:57 AM
Banned
Mein Auto: 2007-335 HTC
I believe eveyone has the issue with the door pull and that plastic crap coming off, it might be covered under warranty if you are within the range of warranty
Old 09-30-2013, 10:05 AM
Originally Posted by bocabimmer View Post
1)
Thanks! That's a really good idea, do you have a recommendation where to get the vinyl?
Old 09-30-2013, 10:11 AM
For the handle, I'm going to try sanding first, looks like I found the replacement handle here: http://realoem.com/bmw/showparts.do?...92&hg=51&fg=50
And I'd rather not spend the $214 if I can just sand off the flakey rubber.
Old 09-30-2013, 01:21 PM
bocabimmer's Avatar
Sure the $214 isn't for the horizontal leather panel?
2014 i3 BEV
