Old 09-30-2013, 01:33 PM
Lee Roy Lee Roy is offline
Mein Auto: 328XI
328XI Vent Temp 10 Degrees Higher Than Outside Temp
I have a 2011 328XI with standard Climate Control. With AC off
and blue / red wheel set to blue, and temp set as low as it will go (60 degrees)
vent temp is at least 10 degrees higher than outside air. This happens on auto
mode as well as manual. No recirculate on. Dealer says this is normal. I find
that hard to believe.
Thanks in Advance.
Lee
Old 09-30-2013, 02:01 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Sounds normal to me, assuming you're doing the measuring with the car stopped in place.
There's no way you're going to get the temperature lower than the outside air temperature without the A/C compressor. If you're on straight outside air, it's coming in through a ducting and filter system that's starts under the hood and ends behind the dash, both areas which will likely be higher than ambient due to the temperature of the engine compartment. If you're parked, you'll also be in a big stagnant pool of air being warmed by the car.
10 degrees above outside in an idling car parked in one place wouldn't surprise me. If the car were in motion and the fan was on high, I would only expect 2 - 4 degrees above outside.
Old 09-30-2013, 02:29 PM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
+1. The outside air comes through/near some very warm places to get to your vents. N4S
Old 09-30-2013, 04:19 PM
surfcity335i surfcity335i is offline
Mein Auto: 2012 335i M-Sport
Thanks in Advance.
Lee
I had an Infiniti FX 35 and the dash vent temps were over 100 degrees when ambient temps were 70! Dealer and Infiniti told me that it was normal and to always have the a/c on. Dopes.
10 degrees I could live with and probably is normal considering where the air is coming from and the temp of the ducting it's traveling through.
Old 09-30-2013, 10:20 PM
Tom K.'s Avatar
Tom K. Tom K. is offline
The trick is to open a window when ventilation (but not A/C) is needed. Unfortunately when it is raining, this means the compressor often needs to be run to avoid fogging.
Tom
Old 10-01-2013, 04:08 PM
hellosopo hellosopo is offline
Mein Auto: 2011 E90 328xi N51
I've found if it's more than about 50 degrees outside, I need the A/C on for the climate control system to be able to maintain 70 degrees. Otherwise it is too warm, as you noticed.
