Old 10-01-2013, 08:06 PM
unotdad unotdad is offline
Mein Auto: 745i
Engine over heating
I have a 2005 BMW 745i and my engine temp to high light came on . Can somebody tell me what could've caused this
Old 10-02-2013, 08:07 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Welcome to Bimmerfest. I've moved your thread over to the E65 7 series forum. You'll be able to get help from other 7er owners here.
Good luck,
Tim
Old 10-02-2013, 09:17 AM
samadkins29's Avatar
samadkins29 samadkins29 is offline
Mein Auto: '03 745Li
Stuck thermostat most likely. If your coolant is not low. If it is low, then you have a leak.
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
Old 10-02-2013, 12:50 PM
ssdriver27 ssdriver27 is offline
Mein Auto: 2003 745LI Alpine White
I wouldn't recommend driving it till you figure it out. could lead to MUCH more expensive fixes.
2001 Camaro Z28 custom built and custom turbocharged 600+WHP @ 14PSI. (SOLD)
1996 Maxima GXE (commuter/camping/Dogs are coming with, car)
Old 10-02-2013, 12:58 PM
First check the fluid level for your coolant and engine oil, check the thermostat, checking those things should give you an indication of what's causing your overheating problem.
Old 10-03-2013, 12:45 PM
Thesatman Thesatman is offline
Mein Auto: 2008 750LI
As was mentioned...
1. wait until the car engine is cool.
2. Slowly open the expansion tank on the passenger side of the engine bay.
3. Listen for the sound of air under pressure excaping.
4. With cap removed, peer down inside and check the level of coolant.
5. While you are at it check the color of the coolant, it should be blue. If it is any other color then I would flush and replace it with BMW coolant.
6. If there are no indications of anything strange up to this point then with the cap OFF, start the car and turn the heater on inside the car. Let it run for a couple minutes.
7. Replace cap, with car running access the diagnostic menu (sometimes called hidden menu- do a search if you don't know what i'm talking about) and monitor the coolant temp for about 10 minutes. If it ever drops in temperature make a note of the temp that occured at. If it goes above 107 degrees C then turn off the car.
8. Wait for the engine to cool (this is going to take a while unless it is really cold outside) and remove the cap on the expansion tank and check the coolant level again. If it still full then it is time to move on to components like the Tstat, water pump, or radiator. REport back with results and we can troubleshoot further if needed.
Good luck.
Sport Package, Rear Entertainment Package, Comfort Access, Cold Weather Package, Smoking Package, L7 High Def Audio
Mods = Powdercoated 149s, Black hood vent and kidneys, LED lighting update, BMW puddle lights (all doors), custom coding by "Triple_O_Coding" (including VIM), updated navi DVD from "PAPER", 90C hybrid thermostat.
Old 02-15-2014, 12:45 PM
Mein Auto: 745i
thanks it was the thermostat and it was easy to replace
Old 02-15-2014, 12:48 PM
Mein Auto: 745i
Thanks the problem was the thermostat and it sits right in the front so it was pretty easy to replace
