Old 10-02-2013, 07:28 PM
wordjay wordjay is offline
WordJay
Mein Auto: 325XI
Audio help
hey how are you all ?
i am noob with BMW so please help me
i bought technic Harness i finely received it today. now i have searched up alot for the questions i have. but i could not find exact proper information from it.
QUESTION.
1. where should i tap in the power for my aftermarket amp.
(i know its from the battery but where exactly from the power bar and should i put in capacitor is it really necessary ?) <<<< if someone can show me a picture or anything like that would be a grate help
2. when i unplug my logic 7 harness to plug in the technic harness should i worry about losing my settings?
3.if i do remove the battery positive or negative will i have to reprogram it?
to help i have logic 7 sound system i drive E90 2006 325XI
http://www.bimmerfest.com/forums/sho...4&postcount=51 <<< i have this harness
Old 10-02-2013, 07:53 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
A technic harness alone will not make and L7 system work.
You have to have the right Technic Harness and reprogram the Head Unit
to Hi Fi or use mobridge da2 as a preamp. You have to understand the way the
L7 works its uses fiberoptics, settings are the last thing you have to worry about.
Its complicated please read
http://www.e90post.com/forums/showthread.php?t=641323
and go here to get your questions answered.
http://www.e90post.com/forums/forumdisplay.php?f=27
Also read these
BMW stereo types
http://www.e90post.com/forums/showthread.php?t=352586
http://www.e90post.com/forums/attach...2&d=1266451970
http://www.e90post.com/forums/attach...2&d=1260829447
http://www.e90post.com/forums/showthread.php?t=343673
http://www.e90post.com/forums/showthread.php?t=138949
http://www.e90post.com/forums/attach...1&d=1209780605
http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/
http://www.e90post.com/forums/attach...1&d=1209780865
http://www.bawarec.ru/manuals/3er/e9...3er-e90-12.pdf
http://www.musicarnw.com/page-2/
http://www.e90post.com/forums/attach...4&d=1278871872
Old 10-02-2013, 08:24 PM
WordJay
Mein Auto: 325XI
Thank you
Old 10-02-2013, 08:29 PM
WordJay
Mein Auto: 325XI
i have this harness
Enhanced Premium Sound/Logic7 Plug 'n Play Trunk Subwoofer Harness
http://www.bimmerfest.com/forums/sho...525&highlight=
Also read these
BMW stereo types
Old 10-02-2013, 08:57 PM
That's the add a sub harness.
You shouldn't loose your settings but I would write them down just to be sure.
You may get some error messages on the dash that will go away once you drive
the car . The radio settings should be stored in the Key Fob.
There are lots of wiring and system examples on the board I pointed you to.
Also it looks like Technic has explained it pretty well.
How big is your amp that will determine if exceeds the capacity of the car to keep up with it.
Technic also sells a power wire kit .
Some people go right to the lugs on the battery be sure to fuse it.
Old 10-02-2013, 10:00 PM
WordJay
Mein Auto: 325XI
thank you very much for all this help and info
i am using 1200W mono pioneer 8500m amp and 10'' pioneer sub i am gonna use 60AMP fuse just to be safe. i also plan to put capacitor on it as well.
Old 10-02-2013, 10:18 PM
FYI might help
FYI might help
http://www.e90post.com/forums/showth...ght=connectors
Old 10-02-2013, 10:22 PM
WordJay
Mein Auto: 325XI
Ctuna
thank you so much for all your help you really did help me clear lot of my questions
thank you
325xi 2006, amp, amp install, amplifier, audio, e90
