Old 10-06-2013, 04:48 AM
goren123's Avatar
goren123 goren123 is offline
Mein Auto: 2011 BMW 750Li xD
Pedalbox Stealth Install
Originally Posted by aom7 View Post
Yeah Goren, something isn't right. Did you compare them side by side to see if the new ones were indeed whiter? I used a set of 25$ ebay ones and they were noticeably improved (whiter).
After running 2-3 min. It is a tad whiter. But still no where near led white. Maybe 4750 color temp is not enough.
Sorry everyone I did not mean to hijack the thread
Back to the topic:
Today is pedal box & BMS install day for me. A little bit concerned about pedal box install. I am confused how to remove center console. Do I need to pull it up or slide the wood trim? I wish I could find a video on how to remove these pieces. I even failed to disconnect the pedal cable at my first try. Wish me luck. Let see what happens next
Old 10-06-2013, 11:12 AM
goren123's Avatar
Installed it! Not to bad for a first timer.Click image for larger version
ID:	400761Click image for larger version
Old 10-28-2013, 11:33 PM
bjames2785 bjames2785 is offline
GIGGITY
Mein Auto: 2009 750Li
Nah, it was just to show you how the clips are shaped to give you an idea of how to remove the side trims, etc. Basically, once the center wood is off, you just slide it forward (carefully).
Aom7 where are the screws for the center wood located? Just ordered a pedalboox and would like to installand run cable your way.
Old 10-29-2013, 05:27 PM
GIGGITY
Can anyone answer my question in the above post? I've been googling and can't find any info. May start a thread if I don't get an answer soon.
Old 10-29-2013, 05:50 PM
GeoX750Li's Avatar
GeoX750Li GeoX750Li is offline
Mein Auto: 2010 750Li X-Drive
I think they are under the cover next to where you push the buttons to open the armrest storage where the phone cradle is.
Old 10-29-2013, 08:32 PM
GIGGITY
Thanks GeoX750li i'll check it as soon as i get my car back.
Old 10-29-2013, 11:55 PM
aom aom is offline
Moderator
Mein Auto: 750i 740i 330ci
Yes, just pop off that plastic silver looking thing that surround the buttons/keyhole. They're just held on by pressure and if anything will probably already be a little loose.
F01 750i Dark Graphite Metallic M-Sport Packages: Driver Assistance | ARS | Luxury Seating | Camera | Convenience | Premium Sound | 20" 303M Wheels | Ceramic Controls
BMS Stage 1 Tune | Pedal Box | M-Sport Paddle Shift Steering Wheel | 5000k HID | Tint | Mtec Angel Eyes LED | Rear Tinted Taillights | Coded
E38 740i Black Sport Packages: PDC | Convenience | Sunshade
Paddle Shift Retrofit | Brushed Aluminum Gauge Ring | Modified M-Sport Steering Wheel | Tint | MKIV NAV | 4500K HID | 3M DiNOC Carbon Fiber Trim | Heated Seats | Refinished M-Parallel Wheels | Celis Tails
My PedalBox Stealth Install: http://www.bimmerfest.com/forums/sho...d.php?t=725889
Old 10-30-2013, 09:48 AM
mr-karim's Avatar
mr-karim mr-karim is offline
bimmerfest coolest Member
Mein Auto: Audi R8 v10 Spyder
When I turn off my car, do I suppose to turn the pedal box off too???
Audi R8 v10 Spyder - Current
2015 BMW i8 - Retired
Lamborghini Gallardo LP560-4 - Retired
f13 BMW M6 Coupe - Retired
f01 BMW 750xi Dinan Stage 5 - Retired
2011 Mercedes-Benz e350 - Retired
Old 10-30-2013, 10:46 AM
Snorlax Snorlax is offline
Mein Auto: _
No. Not needed. It will eventually turn itself off when the car cuts power to it after about 10 min.
Old 10-30-2013, 11:12 AM
goren123's Avatar
I do not turn it off either. However I recommend not to leave it on at sport + mode. Sport + mode some have affecting idle RPM on mine. My default setting is echo with 3+. Knock on wood, not a single glitch.
Old 10-30-2013, 02:43 PM
DLF750's Avatar
DLF750 DLF750 is offline
Mein Auto: 2013 Audi A8L
Now I want one of these suckers. Probably really mess up my already crappy gas mileage though.
GONE (but not forgotten): 2011 BMW F01 750i. Dark grey, black interior. Anthracite headliner, M Package, 760 Quad Tips/Diffuser, PedalBox, Sport Package and a bunch of other stuff...
Old 10-30-2013, 03:49 PM
PREDATOR 007's Avatar
PREDATOR 007 PREDATOR 007 is offline
Mein Auto: 2016 ///M5
That's strange. Mine has been in Sport + w/ level 3 since day one and I have not noticed any RPM issues.
Do you have RWS? Not sure what else it may be.
** Removed ** 19,000th, 22,000th, 22,222th, 26,000th, 35,000th, 45,000th 48,000th, 63,000th, Honorary 87,000th and 93,000 post in delete pls
WR 12.50 @ 112.05 MPH 9/18/14
Old 10-30-2013, 04:03 PM
goren123's Avatar
+1, great diagnosis; no RWS!
Old 10-30-2013, 04:05 PM
goren123's Avatar
Just the opposite. If you use it at Eco mode, you may see slight improvement on mpg. I was running 15-16mpg after pedal box running it slightly higher 17-18 mpg.
Old 11-02-2013, 02:22 PM
mr-karim's Avatar
quick question, my check engine light was on for 3 days, now it turned off by itself! Should I cancel my service appointment?
Old 11-02-2013, 08:34 PM
aom aom is offline
Moderator
I wouldn't. It might just come back, if it's still in memory (which it should be), this is still the best time to have them look at it.
Old 11-02-2013, 08:42 PM
mr-karim's Avatar
Old 11-02-2013, 09:52 PM
Popoemt's Avatar
Popoemt Popoemt is offline
Mein Auto: 2015 750i
Soooo the pedal box fixed your Dinan warning light... very cool!!!
2015 750i
2013 740 Li (Lease End)
2007 G35 (trade-in)
2003 Z06 (Black, 50th Anniversary)
2001 Z06 (Torch Red)
Old 11-02-2013, 10:34 PM
mr-karim's Avatar
Popoemt
The check engine light appeared because I turned the pedalbox on while the car was warming up (bad idea). Well won't do it again
Old 11-05-2013, 02:18 PM
rsk rsk is offline
Mein Auto: 325i
Please let me know where to buy Pedalbox from for my 2011 750LI and 2007 Z4 roadster.
rsk
Old 11-05-2013, 03:17 PM
goren123's Avatar
http://www.pedalbox.com
http://www.motivemods.com
Old 03-08-2014, 06:35 AM
DLF750's Avatar
Should get mine today. Only fear is messing up the wood trim upon removal. Just two screws by the ashtray area? and pop it off?
Old 03-08-2014, 03:12 PM
aom aom is offline
Moderator
That's all there is, the two screws under the armrest lock cover, then carefully start pulling up... working your way to the front... you'll feel the clips releasing.
Old 03-09-2014, 12:24 PM
DLF750's Avatar
Thanks! I bought a set of plastic trim removal tool. might help a little.
Old 03-10-2014, 10:16 AM
CABimmerNation's Avatar
CABimmerNation CABimmerNation is offline
CABimmerNation
Mein Auto: 2010 750i M Sport
Don't pry anything. After removing the screws, all items slide back and out.
Dinan S3, PedalBox, 22" Agetro rims, H&R spt springs, RDsport front lip, coded, paddle shift retrofit, AlpineMSS HID 8000k. All exterior chrome, roof, roof spoiler and everything behind wheels painted black, wing, side and rear reflectors and door handle trim painted white, light smoke on tail lights. Audio: focal separates, earthquake low profile subs under front seats (crossed over as mid base to support the pathetic 4" fronts), arc audio amps, audiocontrol lcq-1 and epicenter, (2) L7 subs.
