E46 (1999 - 2006)
Old 10-03-2013, 05:51 PM
halltristan's Avatar
halltristan halltristan is offline
Bimmer Enthusiast
Mein Auto: 325i and X3
What transmission fluid DID you use during change?
So instead of the typical "which transmission fluid?" post, how about instead we go with what fluid you used and how long ago it was.
Theres no better way to know for sure which fluid someone should use than past results!
Member No. 470379
Old 10-03-2013, 06:00 PM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
ZF 5HP19 on the coupe, Redline D4, 60k miles ago
ZF 5HP19 on the convertible, Redline D4, 7k miles ago
No codes, faults or goofy behaviour ever experienced on either transmission before or after the change.
Old 10-03-2013, 06:38 PM
jimvideopro jimvideopro is offline
Mein Auto: 2006 330CiC
GM transmission, Dexron VI. 500 miles or so since changing at 80k. Car shifts great.
Old 10-03-2013, 11:18 PM
blkonblk330i blkonblk330i is offline
Mein Auto: 06/2000 330i ZSP/ZPP
ZF 5HP19 AMSOIL Signature Series Multi-Vehicle Synthetic ATF at 118k
http://www.amsoil.com/shop/by-produc...?code=ATFQT-EA
Other choice is ZF LifeGuard5 which is original factory fill
http://www.thectsc.com/products/zf_l...ner-14-57.html
Never argue with an idiot. He will drag you down to his level then beat you with experience.
Old 10-04-2013, 02:04 PM
Tommy D Tommy D is offline
Need for Speed
Mein Auto: '05 BMW 330i
Redline D4; 100 miles ago.
'05 BMW 330i - 127,000 miles
'87 Ford Mustang LX 5.0L Hatchback - 249,000 miles
'98 Ford Taurus SE DOHC - 116,000 miles
'05 Mazda Tribute s AWD - 118,000 miles
Old 10-06-2013, 07:48 AM
Bimmer Enthusiast
Anyone with longer miles since fluid change?
Member No. 470379
Old 10-15-2013, 10:32 PM
chet31 chet31 is offline
Mein Auto: 05 330i convertible
Mobil 1 Dexron VI full synthetic, but only about 7K miles ago, sorry.
Old 10-16-2013, 04:16 AM
zQUEz zQUEz is offline
Mein Auto: 325i
I have 60K since my ATF change using Valvoline MaxLife. I have a GM transmission and at the time, it was the only bottle I found that specifically said it was a replacement for 8072B, which was good enough for me.
At 162K, i've never had transmissions issues.
