Brake light - Bimmerfest - BMW Forums
Old 10-04-2013, 06:08 PM
qwerty786 qwerty786 is offline
Mein Auto: 320d e91 touring
Brake light
BMW e91 2009 320d
Hi, all, Got a problem with a yellow handbrake light
I was parked on the curb as I drove and dropped my front wheel off the curb instantly the yellow handbrake light came on I look through the dash service menus it's showing front pads with just dashes no numbers (normal in miles) I have had pads changed 1000 miles ago they are still very chunky last time this happened I tried using the same wire and the light became red and it was a dealers job
I'm scared to try to reset via the dash without changing wire incase it becomes red and I can't afford to go dealers again I've examined the wire it looks perfect seems like it may have recievd a knock from me dropping off the curb
Can anyone help
Old 10-05-2013, 05:49 PM
Mein Auto: '06 AW 330xi
I think one of your wheel speed sensors got damaged or loose.
