E46 (1999 - 2006)
Old 10-05-2013, 03:18 AM
abdullahiadedej abdullahiadedej is offline
Mein Auto: E46 330i
E46 330i low mpg and loss of power & grunt
I have an E46 330i 2003, I noticed within a week:
1. a slight drop in power
2. a change in rumble/grunt
3. a drop in mpg from 18 to 14
4. softer steering wheel
Is it me or something has gone wrong in the last week.
Old 10-05-2013, 09:05 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
You need to find someone with a code reader (even an inexpensive one will work, available online for les than $30 USD), and scan the codes for faults. After you do that, post the results here, and we might be able to help you.
The road goes ever onward....
(R.I.P. Jever)
Old 10-06-2013, 02:30 PM
Mein Auto: E46 330i
I'm a newbie and hoping these can be translated into English. These are what the diagnosis came up with:
123: Activation, map cooling
241: misfire, cylinder 4
238: misfire, cylinder 1
124: Activation, solenoid valve, intake manifold (DISA)
226: Function, oxygen sensor control after cat., bank 2
236: Function, oxygen sensor control before cat. conv., bank 2
204: Plausibility, idle speed (leakage air)
8: signal air-mass flow sensor
Old 10-06-2013, 02:40 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
You need to replace the DISA and the MAF first. At least, that is what I'd do (and recently DID do on my car). Only difference was I had a SUBSTANTIAL loss in power, it wasn't in any way subtle.
Old 10-06-2013, 03:26 PM
Mein Auto: E46 330i
advice taken. will give feedback when done. thnx
Old 07-14-2015, 03:55 AM
Mein Auto: E46 330i
Update: ALL PROBLEMS SOLVED
Changed the DISA, Solenoid valve, spark plugs, & throttle valve (old one was stuck, power improved massively afterwards)
ignition coils were swapped around but misfire remained on 1 and 4.
Over the years several other faults have shown up particularly P0300 (random/multiple cylinder misfire detected) and P0414 (Secondary Air Injection system switching Valve A circuit shorted)
I've done quite a lot of replacements as a result.
CCV vent hose was replaced (misfire problems solved)
I switched to Castrol Edge 5w-30 (oil was still falling short within 2-3 weeks): solution replaced the CCV. Also had the switching valve replaced.
The only outstanding now is the MAF but the baby is running better than ever. Will change it eventually and soon too.
330i, low mpg, softer wheel
