Old 10-05-2013, 05:14 PM
mikesevel's Avatar
mikesevel mikesevel is offline
Mein Auto: 328i convertible '08
My cup holder runneth over
I have an '08 E93. On the console below the shifter and in front of the storage box there is a receptacle that will hold a small cup or car keys. It is lined with a rubberized material and it has been beaten up over the years and starting to look crappy. I would like to replace it with a new receptacle as it is difficult to paint.
I stopped in at the local BMW dealer and was surprised that the receptacle, with my discount, is only $12! Wowee-wow, let's buy it...but...hold on..the parts rep told me it can only be installed if i remove the entire console! So I sashayed over to a service adviser to confirm the story. He agreed that the console must be removed and quoted $440 for labor! Holy Toledo, Dayton, Cleveland, etc.
Ok, has anyone removed their entire console and is it a bear?
Thanx,
Mikey
New Braunfels, TX
Old 10-05-2013, 05:27 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
I had to scan over the recent threads to find this DIY guide that may help you out, I'm glad I could find it, link posted courtesy of jburke just two days ago.
http://www.pelicanparts.com/BMW/tech...eplacement.htm
Old 10-05-2013, 05:39 PM
Mein Auto: '06 AW 330xi
You just lift the trim up, it's friction fit. It will be stubborn to remove, especially if it hasn't been done recently.
It helps to remove the shifter boot first. This allows you grab under the opening and get some leverage.
Plastic pry tools also help but a screwdriver or knife wrapped in tape works ok too.
The tray is held in by torx screws. T20 I believe.
Old 10-05-2013, 06:18 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
Great post. This doesn't look like $440...or 8.8 hrs. @ $50/hr...or even 4.4 hrs. @ $100/hr. A whole new definition of "stealership"? Oh, I forgot the $12.00 bucks for the 'cup holder'.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 10-06-2013, 05:04 AM
sunny5280 sunny5280 is offline
Mein Auto: 2011 X5-M
I've found those store loyalty cards, the ones which are plastic like a credit card, work very well when trying to separate parts on a vehicle.
Old 10-06-2013, 07:48 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
What a PITA for a small "repair"! N4S
Old 10-06-2013, 10:05 AM
Not the center console! It's an extreme tight fit and the first time the trim is removed, it's very stubborn.
I do this regularly since I wrap interior trim in vinyl
Old 10-06-2013, 11:43 AM
Just throwing it out there as a general tip.
