E46 (1999 - 2006)
Old 10-05-2013, 10:19 PM
shannys325xi02 shannys325xi02 is offline
Mein Auto: 2002 325xi
Brake lights malfunction- won't turn off
2002 325xi
Generally my girl runs great. I have had her almost ten years and don't want to give her up! But this problem actually scares me.When I turn the car off and remove my key all of the dashboard warning lights come on and the brake lights go on. It works fine when I am driving it, this problem is only when it is off. I had to disconnect the battery because the back brake lights were getting really hot and I didn't want to start an electrical fire in my garage.
Thoughts on these Gremlins?
Thank you kindly
Old 10-05-2013, 11:24 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Originally Posted by shannys325xi02 View Post
2002 325xi
Thank you kindly
Read all the Sticky Threads at the top of the Forum page....especially the E46 Wiki !
The road goes ever onward....
(R.I.P. Jever)
Old 10-06-2013, 06:10 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
This ^. You'll find a couple good stickies about the brake light wiring issue for which there was a recall and is also a very easy fix, and one about the trunk lid wiring pass fraying and causing all sorts of shorts. The wiki has a section on electrical too. See where you can get with it and then come back if you have more questions.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 10-06-2013, 08:24 AM
Re: Brake lights malfunction- won't turn off
I read through all of the electrical section off the Wiki. Nothing seemed to address this issue. This is different than the corrosion causing the recall issue, I already took care of that. Literally all of the warning lights on the dashboard (picture) and the back brake lights come on when I turn the car off, key out of the ignition.
Thanks for your thoughts.
Sent from my SPH-L710 using BimmerApp mobile app
Old 10-06-2013, 08:59 AM
Fast Bob's Avatar
Keeping it surreal
You`re kidding, right ???
S.T.I.C.K.Y THREAD PSA: Check Your Trunk Wire Harness
(R.I.P. Jever)
