Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 10-06-2013, 09:01 AM
JimM3 JimM3 is offline
Mein Auto: 98 M3
Total Noob looking for advice
I'm new to the BMW world. Driving a 98 M3 sedan with about 150k (daily driver) and looking for advice on practical upgrades. Most of my driving is on the highway. No racing/track.... Also, what type of issues should I be looking out for with a car at this mileage?
Old 10-13-2013, 11:07 AM
jakeg104 jakeg104 is offline
Mein Auto: 997S
man, that's a loaded question. Search some of the sticky threads for maintenance lists.
if you want to keep it feeling stock'ish, then maybe change out the shocks and bushings, which if original, have long outlasted their life. Koni sport shocks, new OEM bushings can change the feel of the car in a strongly positive way
10 GT3 Basalt Black
91 Brilliantrot e30 M3- Restored to Factory
F430 Spider Gated
11 S63
14 Raptor
PREVIOUS LOVES-
02 e46 M3 GTS3 track rat
06 ZCP M3 Sunroof delete 6MT, 11k miles
97 e36 M3 Hellrot on Black
09 Carrera S PDK
91 Spec Miata
98 Dinan Serialed SC M3
95 M3 Lightweight
07 E63 daily driver
2006 ///M3, Titanium/Black Leather, SMG, Nav v31, V1 Hardwired
1999 ///M3, Cosmos/Dove Grey, DINAN CAI, MAF, Software, Throttle body, Exhaust. Deeply Missed.
Old 10-23-2013, 10:04 PM
fresh802 fresh802 is offline
Mein Auto: 1996 328i
A nice cold air intake will give you a better sound. and a bit better mpg.also very east to do. well worth it.
Old 10-28-2013, 06:52 AM
7pilot 7pilot is offline
Git
Mein Auto: 90 Ford Tempo
Important:
Before you start wasting $$ on bling, find out if the cooling system has been overhauled.
If not, then replace the coolant tank, the waterpump, the tstat, the tstat cover and the hoses at minimum.
The plastic components. Of the cooling circuit are very brittle by now.
While you're in there a new radiator would be good.
Worn suspension would be next
m
Old 11-27-2013, 10:20 AM
Frank@AchillesMotorsports Frank@AchillesMotorsports is offline
Past Sponsor
Mein Auto: BMW's
Originally Posted by 7pilot View Post
Important:
m
7pilot is offering the best advice possible.
These are several cooling system upgrades that will decrease your likely hood of being stranded by the brittle factory parts.
We highly recommend changing the parts mentioned like the coolant expansion tank, thermostat, switching to an aluminum thermostat housing and getting a water pump with a metal impeller.
Aluminum Thermosstat Housing
New Thermostat
Stewart Water Pump with metal impeller
Also make sure the necks where the hoses connect to your rad are in good shape or change the rad to eliminate the possibility of them failing after you do all this work, that would certainly be a bummer.
It's also a really good idea to inspect the engine driven cooling fan for cracks, these self-destruct quite frequently and can cause a lot of auxiliary damage to everything around it. A lot of people prefer getting rid of it and switching to an electric fan setup, the added bonus is you theoretically gain an immeasurable amount of power by reducing the drag on the engine from the old fan.
Here is the kit we sell for the fans:
http://www.achillesmotorsports.com/S...-16pullkit.htm
Once all that is sorted then you can move on to the wonderful quirky of the E36 like the oil pump nut issues, rear shock towers and sway bar mounting tabs. The list goes on, but the forum is a good place to look for help and advice.
Also we have no problem answering your questions as well.
Old 12-04-2013, 11:35 AM
albinomidget albinomidget is offline
Mein Auto: '98 E36 M3 Sedan
Everybody has the main stuff covered above. However, my 2 cents:
1. I did a fan delete kit that I really like. Not so much for power but just to get rid of that clumsy clutch fan always in the way of everything else.
2. Main thing on bimmers. They require maintenance often. They are a more sophisticated car all around with many more moving parts than say... a Ford Taurus. Thus, there are more things to go wrong. But the trade off is that you are driving (in my opinion) one of the most functioning, well handling, and fun cars on the road today even up against all of the enormous competition out there.
3. I went back to stock suspension so I have a left over set of Koni sport (yellow) shocks and TC Kline springs I would let go for $400 + shipping. They have about 40,000 miles on them. Let me know if interested.
