E46 (1999 - 2006)
Old 10-06-2013, 10:58 PM
madmick madmick is offline
Mein Auto: 2001 e46 320i
transmission fluid leak [front]
hi thanks to those who helped with information on servicing my zf 5hp19. the saevice went very well.since it has developed a leak in the front of the transmission. at 200ki probably did not catch it in time. however i thrive on diy,can any body point me to someone who has done a write up on transmission removal and seal replacement. apart from the fluid loss, the transmission is quiet and responsive. also i have a haynes repair manuel, this helpfull but inconclusive,could anyone recomend a better manuel. thanks to those who posted info,this has been invaluable.
Old 10-07-2013, 07:24 AM
wdgiles's Avatar
wdgiles wdgiles is offline
You can call me Bill
Mein Auto: 2001 325i
Can't help with a manual or anything like that, I had mine replaced at a transmission shop. Mine was leaking from the bell housing thing that looked like a doughnut, and only under load, so the shop could never find the leak while on the lift. The inside of my bell housing was scrubbed clean from all the fluid sloshing out of it.
*Current* -- 2008 335i Convertible
*Retired* -- 2001 325i - https://picasaweb.google.com/bgiles/2001325i#
Rockwall, Texas
Old 10-07-2013, 07:31 AM
Scottji's Avatar
Scottji Scottji is offline
Mein Auto: 2004 325i
Re: transmission fluid leak [front]
As far as a repair manual, get a Bentley.
Is your tranny an auto or manual? If its a manual, it might be a rear main seal, especially since you say it's from the front of the tranny. Are you sure it's tranny fluid and not motor oil?
Old 10-09-2013, 04:05 PM
thanks for the reply, sorry i wasnt specific.my bad.its an auto,zf 5hp19. its definately transmission fluid.on a test drive, after servicing it went positively and quiet. untill the atf [oil] depleted.about 6miles. it dropped a a lot of fluid. the leak was there before i did the service,in foolish hope, i thought the service would solve the problem. thanks again, i would be completly at the mercy of the sharks if not for this site.
Old 10-30-2013, 04:13 PM
thanks for the advice, i took it to a repairer and discovered the front pump [supply unit] seized on the torqe converter. the whole transmision needs to be over hauled.the cost here in australia is $6000. as the transmision has 120k miles on it, i will replace it with a new one. i will try and get one from the good old USA. fer the moment and just for fun i will try and overhaul this tired old transmision myself. i am fascinated with the 5hp19, it is such a tough unit, i want one for an old one tonne ute i am restoring. so the overhaul exercise will be helpful to me even if it fails. i will post my results/failures on the site.this may save someone some money.
Old 10-30-2013, 04:32 PM
catso's Avatar
catso catso is offline
catso
Good luck! Trans rebuilding is not for the faint of heart. Please let us know your results.
![/I][/FONT]
Old 11-01-2013, 09:23 AM
Tommy D Tommy D is offline
Mein Auto: '05 BMW 330i
Can 't you find a local shop to rebuild your old one vs new and save maybe half the cost?
'05 BMW 330i - 126,000 miles
'87 Ford Mustang LX 5.0L Hatchback - 248,000 miles
'98 Ford Taurus SE DOHC - 115,000 miles
'05 Mazda Tribute s AWD - 117,000 miles
Old 11-01-2013, 11:22 AM
davidmaria1 davidmaria1 is offline
Mein Auto: 2011 X5 3.0 Gasser
I may get heat for this, but, have you checked salvage yards?
The bigger yards are considerably more advanced with their testing and removal than years past.
Old 11-01-2013, 07:34 PM
catso's Avatar
catso
Used is always an option, albeit risky, but so is a manual conversion.
![/I][/FONT]
