Gear box multi plug leak - Bimmerfest - BMW Forums
Old 10-08-2013, 11:23 AM
wendai wendai is offline
Mein Auto: 3 series 320i automatic
I have been quoted 183.33, plus oil filter at 179.90, plus seal sleeve at 10.34, total 373.57 + VAT = 448.28 for the above. No mention of new oil on the estimate. Does this seem reasonable?
Old 10-08-2013, 11:25 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Welcome to Bimmerfest. I moved your thread over to the general BMW forum. If you let us know what year 320i you have I can move your thread to the 3 series forum for you.
Tim
Old 10-08-2013, 11:28 AM
Year of Car
Hiya Tim. Thanks for your help. It is year Oct. 2007. Thanks once again.
Old 10-08-2013, 11:33 AM
tim330i's Avatar
I've moved your thread over to the E90 forum. You should be able to get feedback on your question here.
Tim
Old 10-09-2013, 06:42 AM
Mein Auto: '06 AW 330xi
Manual or automatic?
I'm assuming auto and you're referring to the infamous mechantronics sealing sleeve leak.
As far as I know, the auto trans filter is integrated into the pan itself. So make sure they are actually replacing the whole pan and not just saying they are changing the filter. Request to see the filter. Not sure if all trans were like this though. I know ZF 6HP is. Not sure about the GM trans in some models
Old 10-10-2013, 02:11 AM
Multi plug leak
Yes it is auto, thanks for your reply.
