Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series
3 Series & 4 Series
The BMW 3 Series and 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 09-21-2004, 07:41 AM
BavarianDoc BavarianDoc is offline
Mein Auto: 2014 640xi GC
replacing front turn signal light bulb with higher waltage - problem?
I am planning on replacing front orange turning signal light bulb with clear one. I need a 12V/21W 7440 light bulb as factory, and found a Pilot 7440 White Chrome but it's 27W.
Do you guys think it would cause any problems if I put higher waltage - 27W instead of 21W for front turning signal light?
Any help is greatly appreciated!
Old 09-21-2004, 11:45 AM
Tanning machine's Avatar
Tanning machine Tanning machine is offline
Using SPF 45
Mein Auto: 2004 330Cic
Absent an amber lens, it might cause problems with complying with the law limiting clear lights to headlights and parking (backup) lights, and requiring signals to be amber.
Tanning Machine I: 1989 325iC (Salmon Silver/Black, Heated Seats, LSD). 7/26/1989-11/1/2003.
Tanning Machine II: 2004 330Cic (Silver Gray/Natural Brown, SP, PP, Heated Seats, Xenons). 8/29/2003-present.
Old 09-22-2004, 01:49 PM
gordo325xiwagon's Avatar
gordo325xiwagon gordo325xiwagon is offline
Urban Knucklebuster
Mein Auto: '01 325xit & '93 300zx TT
It is unlikely 6 watts will make a difference on a turn signal bulb. On my 325xi I have gone from 55 to 70 watts on my low beams w/o adverse effects. I think most OEM curcuits have quite a bit of extra capacity built in to their wiring to compensate for increased resistance as the wires wear or age.
I have upgraded hi or low beam wattage on almost all the cars I have owned. After an upgrade I always check the temp of the wires by touch...both at the bulb socket connectors, and at any juncture with a larger part of the curcuit. High resistance causing an overload is most likely to occurr at these points. It has always been my understanding that these wires will heat up long before their fuse is blown. If it is hot to the touch, or even uncomfortably warm, then I rework or rethink the situation. Of course if you blow a fuse you have your answer right there.
Not the best diagnostic, but certainly a practical one.
As noted above, you should first check local and state laws regarding bulb and light colors. IF you have clears, then I am pretty sure that you will need an amber bulb.
Some amber bulbs, show up as silver or clear when not lit, because they have an silver coating on the side visible to the exterior. However, behind that coating is an amber facing that gives off an amber light.
300ZX StgIII (360 rwhp@16 psi) // '97 Jag XK8 - Luxor Cruiser
// 325xit - Best Balance of Ride & Handling
Old 09-22-2004, 02:04 PM
Bavarian's Avatar
Bavarian Bavarian is offline
Oversized Rooster 4.4i
Mein Auto: '02 X5 4.4i
Hey Doc, did you derive your nickname from mine?
2002 BMW X5 4.4i - Titanium Silver, Grey Leather, Activity Package, Front+Rear PDC, Boomerang2 Recovery System, Lumbar Seats, Auto Dimming Mirrors, Sunshades, Privacy Glass, 30% Front Tint
Old 09-23-2004, 08:20 AM
NOPE -- THIS IS THE FIRST TIME TO SEE YOUR USERNAME AND POST FROM YOU.
Similar Threads
Front light problem nash E39 (1997 - 2003) 3 01-12-2011 07:58 PM
Turn Signal Problem? smlewis 3 Series & 4 Series 17 06-17-2004 06:29 PM
Right front turn signal problem Big Al 330i General BMW Questions 10 10-11-2002 11:20 PM
Drivers side turn signal bulb ObD 3 Series & 4 Series 0 08-03-2002 11:35 AM
