Old 10-08-2013, 08:15 PM
Rosie06330i Rosie06330i is offline
Billy Rose III
Mein Auto: 2006 BMW 330i
MAX A/C turned itself off
2006 330i. Started my car, I live in Hawaii so I always press the MAX A/C button as soon as I get in the car. This time it randomly went from max to auto. Pressed it a few times, lasted for a few seconds then went back to auto. Waited a minute, then pressed it again and is now running fine. Is this an issue I should address urgently or should I sweep it under the rug? Thanks for the advice.
Billy
Old 10-09-2013, 12:00 AM
gcreese gcreese is offline
Mein Auto: 2010 535i Sports Wagon
Given that it happened right at the beginning, it may be a sign that your battery is starting to go. BMW has some algorithms that decrease battery drain if the car feels the battery is being overtaxed. If I remember correctly, MAX turns the fan on to full blast, and maybe that was too much at the beginning of the start sequence. See if it happens again if you wait a minute before hitting the MAX button.
2010 535i xDrive Sport Wagon (April 2009): Deep Sea Blue / Cream Beige / Sport, Premium, Cold Weather Packages
2011 335i xDrive Coupe (April 2011, European Delivery): Le Mans Blue / Oyster-Black / M Sport, Premium, Convenience Packages
Old 10-09-2013, 01:00 AM
Billy Rose III
Thank you
Old 10-09-2013, 07:12 AM
bmwrocks's Avatar
bmwrocks bmwrocks is offline
Mein Auto: 2011 328i Convertible
I can tell you that my battery was dysfunctional about a month ago, and even though it would start the car, I was seeing some power conservation symptoms. The blower fan would not blow full speed even on highest manual setting. The welcome lights no longer worked. Dealer diagnosed it as bad battery and replaced it. All is good now.
2011 328i Convertible : Mineral White; Oyster/Black Dakota Leather; Premium, Sport, Value; Sport Wheel w/paddles; Heated Front Seats; Satellite radio; HK Sound
2012 528i Sedan : Titanium Silver; Oyster/Black Dakota Leather; Anthracite Wood; Comfort Access; Side & Top View Cameras; Cold Weather, Premium; Technology;
2004 330ci : Titanium Silver; Gray Leather; Premium, Sport; Fold Down Rear Seats; Xenon Headlights; Navigation System; HK Sound
2001 X5, 2009 528i (retired)
Old 10-09-2013, 08:48 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
This can also happen due to a malfunctioning outside air temp sensor, usually located in the lower front bumper section. These do not always throw codes.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 10-09-2013, 12:57 PM
Billy Rose III
How much would a new battery be?
Old 10-09-2013, 01:19 PM
Tom K.'s Avatar
Tom K. Tom K. is offline
When the wiring to my E46's sensor was destroyed by chipmunks, the CC system functioned normally; except that the compressor would not come on as the car thought the temp was -40o F.
Tom
Old 10-09-2013, 01:21 PM
Tom K.'s Avatar
About $300 to $400 from a dealer - including registration. If your '06 has the original battery, it's probably past due for replacement.
Tom
Old 10-09-2013, 02:16 PM
Registration is when the dealer tells the system via coding that a new battery is installed. According to BMW, the car charges an old battery differently than a new battery, so it needs to know when a new one goes in. Otherwise, the car will overcharge the battery, eventually leading to shorter battery life. There's a running debate on this forum whether registration is really necessary. Some say it is, some say it isn't. However, the separate registration process is why the fee is so high. One option is to have a third party install a new, appropriate battery, and then have the BMW dealer do the registration. The total price may be cheaper than having BMW do both parts of the process.
Old 10-09-2013, 02:19 PM
surfcity335i surfcity335i is offline
Mein Auto: 2012 335i M-Sport
What a scam. Just another way to part us from our money. Next we're gonna have to code the new air in the tires at 1hr labor so the car knows the old air is gone.
Old 10-09-2013, 03:19 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
I'm hoping to learn how to DIY register it when the time comes. I've heard that some indys charge much less, I think people may have mentioned on the order of $50 or so. Of course, it sounds like you think it's BS and I can respect that opinion, but myself I'm going to register...
Old 10-09-2013, 03:28 PM
Oh, I think I'd register, too. The BS refers to the designed-in need to do it.
