Old 10-09-2013, 08:40 AM
welshrider01 welshrider01 is offline
Welshrider01
Mein Auto: 2008' 328i
Exclamation passenger side mirror failure
Hello all,
can anyone tell me how I can get my passenger side mirror to rotate downwards when I put the vehicle in reverse? it no longer does this automatically...
Old 10-09-2013, 08:54 AM
surfcity335i surfcity335i is offline
Mein Auto: 2012 335i M-Sport
Originally Posted by welshrider01 View Post
Hello all,
I think you have to have the mirrors' R-L adjustment switch slid to the right.
Old 10-09-2013, 09:16 AM
Hello all,
I think you have to have the mirror's R-L adjustment switch slid to the right.
Old 10-09-2013, 09:41 AM
Welshrider01
Exclamation Passenger mirror failure
I'l try that thank you. if it doesn't work does anyone know if this is a fuse issue? thank you in advance...
Old 10-09-2013, 10:55 AM
Banned
Mein Auto: 2007-335 HTC
Should be the switch deal
Old 10-09-2013, 11:21 AM
I just tried it in my 2012 335i coupe and it worked even with the switch over to the left. This leads me to believe that you set it up through the settings menu.
Old 10-09-2013, 01:28 PM
Mein Auto: '06 AW 330xi
The switch is suppose to be to the left to work. If it's to the right, it doesn't tilt.
Old 10-09-2013, 02:41 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
The E90 Owner's manual says: "Activating (tilt function)...Push the switch to the position for the driver's side mirror, (arrow 1)".
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
