This is important for every BMW owner who has an Alarm System which also incorporates a Motion Detector:
I frequently take the BC Ferry from Vancouver Island to Vancouver . Once the ferry starts moving there is often a number of vehicles with alarms sounding, off and on every several minutes. Reason. The Motion Detector is ON and the movement causes it to go into Alarm.
BMW Manual instructs you to depress the round lock button twice holding it the second time. BMWs,MBs,Volvos,Audis with both door and interior alarm systems will go into alarm.
SOLUTION: After a process of elimination I discovered the solution and,despite telling BMW about it appears owners are not getting advised and the manual, since 2011 is still the same.
- Get out of the car
- Press the UNLOCK button TWICE which OPENS ALL THE DOORS(otherwise the system 'sees' only the front door/s).
- Then press the round button slowly, TWICE, holding the button in the second time until you see the RED lamp PAUSE and then blink steadily.
Note: If when you press the button twice the lamp does NOT PAUSE on the second ress, the doors have NOT all been opened. So repeat the procedure.
2. Since I started this procedure, as my dog is often in the car, there have been NO problems. I spend much time instructing frustrated car owners about this. One Bentley Convertible owner had the problem and I showed him what to do,He was amazed.
TELL EVERYONE ABOUT THIS AS EVEN IF YOU DO NOT TRAVEL BY FERRY ANY MOVEMENT OF YOUR CAR INADVERTENTLY COULD TRIGGER THE ALARM. NORMALLY THAT IS OK TO DETER INTRUDERS BUT NOT/NOT WHEN ON A FERRY OR WHEN VEHICLE IS BEING TOWED OR TRANSPORTED.
Also tell your BMW dealer BMW HQ.
al
al
