Sparkplugs? - Bimmerfest - BMW Forums
Old 10-11-2013, 11:20 AM
Averdi's Avatar
Averdi Averdi is offline
Mein Auto: BMW 325i 2006
Sparkplugs?
I've had my car for about 5k miles now. Love it. I'm just wondering when should sparkplugs be switched out? I feel like they haven't been changed in awhile and id like to be ahead of the game. And is it a easy DIY ? Thanks
2006 325i
Red intake scoops, Red taillights, Red calipers, M3 rep wheels, M bumper, 28% tints, 6000k Angels & Fog lights, clear cornered headlights, Black and White emblems, Smoked side markers
Old 10-11-2013, 11:24 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Easy job, you just need a good torque wrench. I use one like this:
http://www.amazon.com/Neiko-4-Inch-A...I3J15ZQ1OYDTR5
No anti-seize and no dielectric grease should be used.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 10-11-2013, 11:31 AM
Averdi's Avatar
Sparkplugs?
I should do coils as well right?
2006 325i
Old 10-11-2013, 11:33 AM
thekurgan's Avatar
Bad Lieutenant
I wouldn't unless you have misfires or codes alluding to misfires. They are not cheap.
Ilse
Bruna
BMWCCA #453648
Old 10-11-2013, 11:35 AM
Averdi's Avatar
Sparkplugs?
I was thinking this could be a reason for my lose of power at times
2006 325i
Old 10-11-2013, 11:44 AM
thekurgan's Avatar
Bad Lieutenant
Not likely; they either work or they don't work and there are almost always codes present when there is a misfire.
Ilse
Bruna
BMWCCA #453648
Old 10-11-2013, 11:47 AM
Averdi's Avatar
Sparkplugs?
I was throwing around misfiring a little too much. I didn't exactly know what it meant. My car doesn't have a misfire havs
2006 325i
Old 10-11-2013, 11:58 AM
thekurgan's Avatar
Bad Lieutenant
Plugs for now, check air filter. Maybe look into this vanos solenoid cleaning thing that was brought up here several times, sounded like an easy DIY as well.
Ilse
Bruna
BMWCCA #453648
Old 10-11-2013, 12:50 PM
ctuna ctuna is online now
Mein Auto: 325xi wagon
How many miles on the car?
They plugs are suppose to be good for 100k in 325 or at least 90k
The Mike Miller old school schedule says 60k not because the plugs will
necessarily be bad but to get them out before they have a chance to seize in
place and to inspect the plug area for signs of oil leakage.
My Indy insists 80 to 90 k will be about right and I am wasting my money t
to change them earlier.
If you are really interested in doing a lot of preemptive maintenance Google Mike Miller BMW for the
old school maintenance schedule. If you car is running OK I would look into changing out the lifetime
fluids first.
Easy source of DIY's
http://www.e90post.com/forums/forumdisplay.php?f=16
Old 10-11-2013, 02:00 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
Averdi, I encourage you or anyone to do them, I just did them for the first time, it was actually fun. Having done some fluids too recently, a couple of those aren't so fun, dirty, messy, smelly, more dangerous with a 3600 lbs car above me.
For my car, I used the video made by Cobb, it is a very well done video.
Plugs for my N54 were only $69 for the set of six from Burger. I used their thin walled spark plug tool. It will get scratched, it is normal.
You will very likely find that cylinders 5 and 6 will be the most fouled. So you can advance your BMW nerdiness, all straight sixes use the firing order of 1 5 3 6 2 4.
I wish I had some sort of magnetic type of 5mm hex bit, because the rear right bolt that holds down the plastic engine cowl, I was a bit afraid of dropping it. (Anyone know where I can find one?)
I learned after the job was already done, that I could have removed the right black strut tower brace for easier access to I think it was cylinder 5. Instead I futzed around, by using only the extension (no wrench) to get the plug in/out, then attached the wrench and went at it. I got the job done, but a wee bit tricky.
Good luck!
Oh, I'm sure it's all placebo, but I swear my car runs happier after the plug change.
Old 10-12-2013, 10:07 AM
Averdi's Avatar
Sparkplugs?
Good luck!
Do you have a link of where to order the plugs? And thanks for advice I'm going to have to try it soon
2006 325i
Old 10-12-2013, 12:34 PM
thekurgan's Avatar
Bad Lieutenant
Go to realoem.com or penskeparts.com, plug in your model, search the engine components for the part number. google: bmw + "< part number here >"
You'll find hits from sparkplugs.com to Amazon.com.
Ilse
Bruna
BMWCCA #453648
Old 10-12-2013, 04:12 PM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
You can get a small tool that will magnetize & de-magnetize your bits & other tools. They are about $3 to $5. On plugs in a 335 about 50K miles or if modified for more boost 25K miles.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPSK/MPE 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
477 WHP of BURBBLES
HOME FROM PAINT
Old 10-14-2013, 12:11 PM
wooohooo
Thanks bear, I had no idea. I'm seeing $5 and up, just added a $6.50 Wiha to my Amazon cart. Sweet!
BMW recommends 45k interval for spark plug change. No tune here, but I'll be doing them every 30K. After I finally hit 90K miles many years from now, I will only have "overspent" by $69 or so.
Old 10-14-2013, 12:16 PM
If you do your own you will need the very thin wall magnetic deep plug socket.
http://www.burgertuning.com/N54_BMW_...t_adapter.html
Kevin
CURRENT:
477 WHP of BURBBLES
HOME FROM PAINT
Old 10-14-2013, 01:14 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Be glad you left it alone, if you had not planned for it in advance. The bolt that attaches the tension strut to the cowl is a torque-to-yield piece that must be replaced if removed. It is also necessary to take care not to pull the grommet, through which the strut passes, out of the cowl when removing the strut, as it may not be possible to reinstall/reseal it properly.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 10-14-2013, 01:24 PM
wooohooo
Oh! Thanks!!
