Loosing my mind - Bimmerfest - BMW Forums
Old 10-12-2013, 04:28 PM
jbonly21's Avatar
jbonly21 jbonly21 is offline
Mein Auto: 02 525I SPORT
Loosing my mind
My piston rings on # 3 are gone, don't know what to do?
02 525I Sterling Gray, 18" M Parallels, M Tech bumper, Magnaflow Highflow cat, Resonator delete, 3" OBX muffler, H&R spring and Bills sport shocks.
RIP ALPINE WHITE 97 528I
Old 10-12-2013, 04:58 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
How could that happen? Is this base on your compression test data?
Old 10-12-2013, 05:07 PM
jbonly21's Avatar
Loosing my mind
Yep, the piston is folded with oil, and non stop misfire on # 3.
Old 10-12-2013, 05:45 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
Cracked head?
Old 10-12-2013, 05:52 PM
dtadrian's Avatar
dtadrian dtadrian is offline
BMW's are like women. $$$
Mein Auto: 1994 540i
Loosing my mind
Originally Posted by ztom View Post
Cracked head?
++++1. This is most likely your case
1999 528iT Sold
1994 540i Toy
2014 Jetta Turbo APR stage 1 daily driver.. FUN!
Old 10-12-2013, 05:57 PM
jbonly21's Avatar
Loosing my mind
Why do you guys think that, for what I have read piston rings is a common problem with this engine.
Old 10-12-2013, 06:34 PM
525isport's Avatar
525isport 525isport is offline
Mein Auto: 2003 e39 525i sport (uk)
the only way to know is to open up the engine and check for how much damage there is . then decide next step ,repair or replace engine
2003 525i sport uk import .see pic ^
1997 300 Tdi Landrover Defender
Old 10-12-2013, 06:39 PM
jbonly21's Avatar
Loosing my mind
I know, but I really don't feel like rebuilding another engine.
Old 10-12-2013, 06:47 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
How do you know it's an oil problem with the rings?
Have you done a compression test? What did you get on cyl 3?
2000 540/6 Slightly tweeked...everywhere
Old 10-12-2013, 06:52 PM
dtadrian's Avatar
Loosing my mind
Have you ever overheated?
1999 528iT Sold
1994 540i Toy
Old 10-12-2013, 07:00 PM
jbonly21's Avatar
Loosing my mind
Is been smoking, burning oil for over two months, even after replace CCV. Yesterday it started knocking, ticking and had a none stop misfire on #3. When I check my plugs all my pistons is cover with oil. It could also be a valve seal leak, and the car sounds a diesel truck. A compression test won't tell me anything I don't know already. Either one of the two is a big job.
Old 10-12-2013, 07:20 PM
If your oil control rings are all carboned up about the only thing you can do short of ripping it apart is to take the plugs out and flood the cylinders with AMSOIL Powerfoam. Let it sit for a few hours and crank the engine over for a 2-3 seconds.
Then let it sit over night and spray a little more in each cylinder. Let it sit for a few more hours, put the plugs back in and fire it up.
Powerfoam does a good job at softening up carbon. If your rings are stuck in the pistons this is one of the easiest things to free them. Might not work in all cases, but worth a try.
Powerfoams works best if the engine is hot, not so good for removing the plugs if the engine is hot.
How many miles on your engine?
Change the oil after doing this if it helps your misfire and oil problem.
Old 10-12-2013, 07:35 PM
jbonly21's Avatar
Loosing my mind
Never overheated
Thanks Jim I will have to give this a try. I am also going to try Lucas stop leak. I just swatch from 0 40 to 10 30, could this has anything to do with it? I just hit 136k.
Old 10-12-2013, 07:40 PM
Never overheated
Neither of those weights should be a problem.
I used 5-30 for the first 12 years and then switched to 0-40, I'm not burning oil. I'm at 140K.
Old 10-13-2013, 10:57 AM
EconoBox EconoBox is offline
Mein Auto: 2001 330i
Was the car driven hard?
My E39 has 138k miles, so I'm not liking this thread!
Old 10-13-2013, 12:44 PM
jbonly21's Avatar
Loosing my mind
Sometimes, not all the time.
Hi Jim, do you know where I can find Amsoil power foam in store?
Old 10-14-2013, 03:28 AM
jbonly21's Avatar
Loosing my mind
I just did a compression test, and I was right. All cylinders are 120-150, except for # 3. The max I got on 3 was 90. How bad is this? A leak down test is next.
Old 10-14-2013, 04:11 AM
Those numbers don't look good, especially #3.
I ordered Power Foam directly from their website.
http://www.amsoil.com/shop/by-produc...?code=APFSC-EA
Old 10-14-2013, 04:16 AM
jbonly21's Avatar
Loosing my mind
I know, is seafoam the same or not? Don't want to wait on shipping.
Old 10-14-2013, 06:31 AM
poolman poolman is offline
Mein Auto: 525i station wagon
Seafoam is good stuff--but for what your doing I would stick to Jim's advice--on your oil--many of us are running 15--w 50 weight with no problems--and I have used the Lucas stop leak--works well. Come to think about it BP Blaster may be good down those piston wells--See what Jim thinks of that stuff.
Old 10-14-2013, 06:52 AM
jbonly21's Avatar
Loosing my mind
Thanks Poolman, I will stay away from seafoam. Jim what's your thought on BP Blaster?
Old 10-14-2013, 07:05 AM
jbonly21's Avatar
Loosing my mind
Just found out Amsoil power foam is not an option for me in Ca.
Jim can you recommend any other product.
Thanks, for the help.
Old 10-14-2013, 09:22 AM
You had 90lbs in cylinder 3--that means that the rings are still there,,just not doing much of a job. If you can get the PB Blaster and poor it into 3 and Iguess it wouldn't hurt to poor in the others as well,,then let it set overnight--turn over slowly and poor again---I would rmove the 02 sensors when doing this and have something like a hair dryer or heat gun to blow down the holes where the plugs go in and where the 02 sensors are--don't know what this stuff will do to the cat's
Old 10-14-2013, 12:26 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Did the OP run a leakdown test?
Old 10-14-2013, 01:35 PM
jbonly21's Avatar
Loosing my mind
Not yet.
