Old 10-12-2013, 06:03 PM
München München is offline
Mein Auto: 540i
Forcing a 540 to crank with half the electrics disconnected
Hi all.
Does anyone have any neat tricks for getting the starter motor to crank the engine on a 540i with most of the engine electronics? It wont even think about letting me do that at the moment.
I am trying to break the crankshaft bolt with an old trick.
Bridging the starting relay do it?
Old 10-12-2013, 06:28 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Yes, you can jump the connection to get the starter to engage.
2000 540/6 Slightly tweeked...everywhere
Old 10-12-2013, 07:00 PM
Mein Auto: 540i
Thanks VM
Forgive my ignorance but where is the starter relay? Above the battery in the boot?
Old 10-12-2013, 07:04 PM
What year 540? It could be behind the glove box or you may not have one.
You can jump it right at the starter.
Old 10-12-2013, 09:32 PM
Mein Auto: 540i
Thanks buddy.
Mines a 2000, only fuses in the gloves box, couple of relays in the boot could it be one of those?. I was trying to avoid climbing under the car to do that considering the jolt from breaking the crankshaft bolt...
Old 10-13-2013, 06:30 AM
Originally Posted by München View Post
Thanks buddy.
You should add 2000 to your sig.
You don't have a dedicated starter relay. The EWS module sends power to the starter solenoid. There is a small sealed relay inside the module that is soldered to the PC board, PITA to get too. You need to pull the lower dash on the drivers side off, it's below the headlight switch.
You could always connect a few wires to the starter solenoid, run them out from under the car and then connect them to engage the starter.
Old 10-13-2013, 12:18 PM
Mein Auto: 540i
Thanks for the help.
That sounds like a plan... couldn't seem to be able to sign in to edit my garage for some reason...
Old 10-13-2013, 02:38 PM
BeamerandBimmer BeamerandBimmer is offline
Mein Auto: MG M4
Let me know how it goes with breaking the crankshaft bolt loose. I'm about to start the timing chain guide replacement. Take some pics if you get a chance please.
Current BMWs
2016 Azurite M5(Almost Here)
2015 Mineral Gray M4
2010 R1200GS Adventure 30th Anniversary Edition
2016 S1000XR
Past BMWs
2014 S1000R
2013 Carbon Black X5 50i M-Sport
2010 Alpine White 135i M-Sport
2010 Carbon Black M5
2007 Graphite K1200GT
2008 335ia
2005 545i
2004 R1150R
2003.5 M3 Cabrio
2000 540ia
1997 M3 sedan
1997 540ia
Old 10-16-2013, 02:05 AM
Mein Auto: 540i
Do we know which of the control solenoid terminals you need to jump to the power terminal on the solenoid?
I have just tried both and while the smaller one seems to have no impact at all the larger one seems to engage the pinion but neither seem to fire the starter motor.
Old 10-16-2013, 03:36 AM
You still have the ground strap from the body to the motor connected, right?
Old 10-16-2013, 10:22 AM
Mein Auto: 540i
Yes all still connected. I have made up a couple of wires with alligator clips so that I can make the contacts while I am NOT under the car. Do I have to connect both control terminals to 12v at the same time?
Old 10-16-2013, 02:43 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
The key may has to be in run position for the engine to start.
Old 10-16-2013, 02:49 PM
HTK12 HTK12 is offline
Mein Auto: E39 540i
Originally Posted by 16valex View Post
The key may has to be in run position.
No need if you give direct power to the starter. Starter doesn't care where the electricity is coming, just that it's coming. I don't think OP is trying to start the engine, just trying to spin engine enough to loosen the jesus bolt.
Old 10-16-2013, 06:19 PM
Just make sure it's not in gear, don't need key in either.
Old 10-16-2013, 11:57 PM
Mein Auto: 540i
Thanks VM.
Unfortunately that only gave the pinion click but no starter motor engagement...
Old 10-17-2013, 04:36 PM
Did it start OK before you started taking it apart?
Have you checked to see if the metal jumper on the solenoid isn't rusted and broken?
Old 10-17-2013, 11:36 PM
Mein Auto: 540i
It started like a champ before and all looks good.
I am going to charge the battery even though everything else works.
I also tried it with the key in and in every position... Weird.
Old 10-19-2013, 01:09 PM
Mein Auto: 540i
The battery was well charged.
I am going to make some gruntier jump leads and see if that helps.
Do we think I need to power both control terminals?
Does anyone know what the other one is for?
Old 10-19-2013, 04:54 PM
Mein Auto: 540i
Ok so it works.
It is a pity I cant use this method to torque it up again.
The issue was too much voltage drop across the jump wires. So I used 2.5mm speaker cable.
I used the jack to hold the 3/4" breaker bar on the bolt and a block of wood to spread the impact load onto the body.
It needed about 15 hits over about 1/2 a turn before it came loose. It works best if you let the bar have a bit of a run up before it hits the wood. Say 1/2".
The engine was not jumping all over the place so I think the engine mounts were OK and after all it is only 300ft/lb of torque. See photos for more detail.
ID:	403025   Click image for larger version
ID:	403026   Click image for larger version
ID:	403027   Click image for larger version
Old 10-20-2013, 04:50 AM
Good to hear you got the bolt out and that method actually worked.
So you used the jack to keep the socket in place, nice.
That other wire on the solenoid goes to the fan in the bottom of the DME box IIRC.
Thanks for the update.
Here's how we did it.
http://forums.bimmerforums.com/forum...o-lots-of-pics
Old 12-07-2013, 09:26 AM
Mein Auto: 540i
Hi all.
This guys says that there are two wires on the EWS that you can bridge in order to get the car to crank with out spark or fuel.
Any idea which these two wires are?
