Old 10-12-2013, 07:18 PM
electricrc68 electricrc68 is offline
Car Enthusiast
Mein Auto: 2008 BMW 328xi Coupe
Steering Wheel shaking/vibration during hard cornering?
Hey guys. I just noticed today when cornering hard that the steering wheel of my 2008 328xi coupe exhibits a vibration/shaking in it. Its when I'm turning hard and accelerating hard into the corner, or just turning into the corner sharply. Its not a lot of vibration/shaking, but its noticeable in the steering wheel. Is this normal? I just want to know if it is normal before I become too worried.
Old 10-12-2013, 08:00 PM
Bigrob126's Avatar
Bigrob126 Bigrob126 is online now
Mein Auto: 2010 328i Coupe Auto
Shaking would not be normal. Could be a tire or suspension issue, and being all wheel drive, could be a driveline issue as well. Hard to say.
Rob
Old 10-12-2013, 08:11 PM
Car Enthusiast
I got the suspension all fixed up a couple weeks ago, so I don't think it could be that. Might be the tires or driveline. Idk...I'll have to drive it again tomorrow and see if it does that when cornering hard. It might have just been more of a road feeling since the roads here aren't great, but I *think* it was shaking. Going to have to definitely check it out again tomorrow.
Old 10-12-2013, 08:42 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Don't drive another mile without first checking to ensure that all your lugnuts are present and tightened to spec. I believe 88 ft. lbs. is correct for your car.
Old 10-13-2013, 05:13 AM
Car Enthusiast
Thanks! I don't have the tools to do that, so I'm not sure how I would figure that out.
Old 10-13-2013, 06:44 AM
Miller335 Miller335 is offline
Mein Auto: 2007 E92
Torque wrench is $50-$100.
Or you could just first make sure none are loose with a 1/2" drive ratchet or equivalent
Old 10-13-2013, 06:45 AM
Car Enthusiast
Ah okay thanks.
Old 10-13-2013, 07:14 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Well let's see.....
Model year 2008 - ~5 years. Has it been normal? NO? Ok we got that outatheway.
Possibilities include tire, wheel, and suspension issues. If you're not familiar with DIY for that, time to take it in. DSX's warning is good advice - if loose lug nuts, very unusual, can be big trouble just turning the first corner from your driveway....think: Collision. Do as he says!
Old 10-13-2013, 08:21 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Originally Posted by CALWATERBOY View Post
Well let's see.....
Cal, it's unusual, agreed. What concerns me is his comment that he recently had suspension work done. There's always the possibility that the lugs were not torqued/tightened. It happens.
Old 10-13-2013, 08:34 AM
Let's have a second look here.
What's recently changed that could affect cornering feel?
Old 10-13-2013, 08:41 AM
Have to wonder what suspension work by who.....
OP, I am totally, unforgivably remiss!
Name:  Jack O Lantern 02.jpg
Every time suspension work's done, alignment's needed. Incorrect toe, for instance, will cause a shudder in certain conditions. Many possibilities here, all due to poor alignment.
Must be this relaxed, sleepy Sunday morn. Or, maybe All Hallow's Eve encroaches on my Wah. Whatever. I am remiss.
Old 10-13-2013, 09:51 AM
Car Enthusiast
I checked the Lugnuts and they are all there. Haven't checked if they are tightened down all the way. I got the suspension work done from BMW of Reading (BMW dealership) and the work was strut bushings replacement that were going out. They also changed both rear tires and rebalanced the tires. Now I know it wasn't a good idea, but I went out to drive it again, and it wasn't much of a shake, but more of a tire slipping kind of feeling...like traction loss. There was no screeching from the tires, so I guess I wasn't turning it too hard. Maybe thats what I perceived was a shaking steering wheel? I must have perceived it wrong since it was at night and I was tired yesterday.
Old 10-13-2013, 10:52 AM
floydarogers's Avatar
Pedant and Curmudgeon
It's possible that traction control/dynamic stability control could be kicking in and the OP is feeling the braking action. Did you notice a flashing yellow icon on the dash?
Old 10-13-2013, 10:59 AM
Car Enthusiast
I didn't notice anything on the dashboard, but I wasn't exactly paying attention to the dashboard when turning.
Old 10-13-2013, 11:23 AM
Don't see nothin' about no alignment. Do you have a Kinematic Alignment readout? Absolutely required after work you had done.
Old 10-13-2013, 11:27 AM
Lug nut torque is critical. Uneven or wrong torque for instance can create the feel of warped rotors.
BMW dealers are generally religious about correct torque, or should be. If you do any work yourself, you need one - here's what I use.
Name:	Thumbs Up 06.jpg
Old 10-13-2013, 11:28 AM
Car Enthusiast
No I do not have one of those unfortunately.
The torque wrench link seems to be broken, BTW. I also thought that BMW dealers would be religious about that too, but I'm not so sure...
Old 10-13-2013, 11:31 AM
The torque wrench link seems to be broken, BTW. I also though that BMW dealers would be religious about that too, but I'm not so sure...
You're quick! Give it another click....
Old 10-13-2013, 11:46 AM
Car Enthusiast
Its working now! That torque wrench is quite expensive, but its something that one must have judging from the replies in this thread.
Old 10-13-2013, 11:49 AM
It is - I use it for many tasks. For lug nuts only, 3/8" unit, doesn't have to be electronic and no angle past torque needed, quite a bit less.
Old 10-13-2013, 12:30 PM
Car Enthusiast
Oh okay I see. Thanks! I'll have to search around and see what I can find.
Old 10-13-2013, 07:57 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
They're religious about it until a dealer tech gets distracted and forgets to tighten the lug bolts. Every year in the U.S. tires mysteriously get dislodged from cars and heavy trucks. An essential part of my "kit" is a torque wrench.
This may or may not be your issue, but DSX is correct in recommending that you have this checked right away.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 10-14-2013, 05:55 AM
Car Enthusiast
Thanks! I'll do that then.
Old 10-14-2013, 06:06 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Oh man, good point! A bad wheel speed sensor can trigger* the ABS during low speed turns. And the 'feel' would fit what the OP describes as symptoms. The OP will have to double check for a dash light.
*Huge problem on rust belt GM's with cast iron tone rings which crack due to rust. The computer then picks up the miniscule gap as a rotation time increase, therefore a skidding wheel.
Old 10-14-2013, 06:05 PM
Car Enthusiast
Okay guys so I'm going to be getting it checked soon since I have to take it in anyway for a rear tire with a small tear in the sidewall (came like that when I got it changed...don't know how that happened). But after reading the above post and floydarogers post, should I try it again with DSC/DTC deactivated and see how it feels then? I'm not sure I would want to turn it off when not on a race track though. I mean the shakes aren't really bad...I don't even know if they even are shakes (better safe than sorry though)!
