The X5 SAV Forum
Old 10-13-2013, 02:21 PM
tiff tiff is offline
Mein Auto: BMW X5 3.0D sport
X5 diesel non start
Hi
Got a 03 x5 diesel sport that cranks but won't fire.
Had both fuel pumps replaced (brand new)
Glow plugs replaced
Crank sensor
Fuel pressure sensor
Starts occasionally but 95% of time won't fire.
Please help
Thanks.
Old 10-13-2013, 08:27 PM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
From my limited experience of the CI engine the only reasons it will not start is lack of fuel, air or compression. It must have the correct mixture of vaporized oil and air at the correct time of the compression cycle. If you have fuel/air then you need to run a compression test.
GL
Old 10-14-2013, 01:49 AM
Forgot to mention, only time it does start is if it's cold I.e mornings,
When it's warmed up it just turns.
Thanks again.
Old 10-24-2013, 04:48 AM
Injector
Old 10-24-2013, 07:38 PM
blomshar blomshar is offline
Mein Auto: 03 BMW X5
I have 4.4 x5, but I have a cummins too, same problem, and in my investigations I found that it is definately in the injection pump, mine was new as well, but sometimes from sitting on the shelf, the pump could have a bad diaphram in it, hope this will help.
