Old 10-14-2013, 04:31 PM
baller330 baller330 is offline
Aaron Garza
Send a message via AIM to baller330
Mein Auto: Grey 2006 330i
Interesting question
I'm a skateboarder and when you have the best bearings in your wheels you roll for a longer period of time. I wonder if this comes to play in a car. If there is some way to increase distance rolled without much fuel consumption.
Old 10-14-2013, 05:07 PM
bigdaws bigdaws is offline
Mein Auto: 335is
It's applicable, but not to the extent you might think. The reason it makes such a big difference on a skateboard is that, in general, skateboards come with VERY CHEAP bearings to keep the cost down. In a $100 skateboard, spending an extra $20 on bearings is a massive difference in cost.
In a car, especially when fuel economy and ride quality are so important, nobody cheaps out on those components.... and even then, "the best" aren't that expensive.
There are other reasons good bearings are particularly important in a car -- the reason good one make a difference is that they convert less kinetic energy into heat. On a skateboard, there isn't much kinetic energy to convert. In a car, a bearing with a lot of friction is going to get incredibly hot very fast, and be completely unreliable.
Old 10-14-2013, 06:17 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
You're unlikely to improve on stock bearings.
Old 10-14-2013, 06:27 PM
twhisten twhisten is offline
Drive it like u stole it!
Mein Auto: 2016 M3
If I put a BMW roundel on my skateboard, do my bearings automatically get better? Or it will just be more expensive to replace?
1997 328i- retired
2007 328i- retired- lease
2006 330xi- retired
2011 335xi-PCD-12/13/10 - DINAN3-----retired
2013 M3-Laguna Seca-6 speed-EDC ------retired
2016 M3
2006 X5- retired
2011 X5- retired- buy back
bmw cca#443379
Old 10-14-2013, 06:39 PM
Aaron Garza
I don't even know a car had bearings. I just feel like my car could keep a better constant speed than it does.
Old 10-14-2013, 06:40 PM
Aaron Garza
Lmao
Old 10-14-2013, 06:44 PM
Aaron Garza
Thanks for your feedback
Old 10-15-2013, 07:08 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
There's a lot more factors at play with a car than a skateboard that slows it down.
Generally speaking, if an automaker (especially in today's business climate where automakers are beta testing everything on consumers) hasn't put it on their car already there's probably a cost/QC reason for it.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 10-15-2013, 07:11 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
lol two VERY different situations, weight, size, momentum - know your physics quantities
Old 10-15-2013, 07:38 AM
Mein Auto: '06 AW 330xi
I think it has more to do with momentum/weight of each subject.
You have tons of weight to keep a car moving but you only have body weight to keep the skate board moving.
So it's going to be noticeable when you put better bearings on a skateboard. Same if you use lubricant on the bearings, you'll fly.
Keeping your tires properly inflated is kind of like the equivalent to better bearings on a skateboard.
Old 10-15-2013, 12:26 PM
mossman35 mossman35 is offline
Mein Auto: 2016 340 Xdrive Msport
Actually, compared to my previous car, this one rolls forever!! I have gotten into the habit of pulling into the lot at work and leaving it in neutral. I just roll right into my spot.. quite a distance slight downhill.
I couldn't cost this far in the same lot with my previous manual transmission cars.
