Old 10-15-2013, 05:16 AM
Vincenteveraert Vincenteveraert is offline
Mein Auto: 330 ci 2007
Angry oil leak
BMW 335 ci 2007
We replace almost every gasket, oil pan, main seal twice, crank sensor or ring
Valve cover, we put a new PCV valve which include the valve cover, any other trick
A pain in the neck
Also since we remove the transmission we have a rattling noise when pull the shifter to the left ?
Any idea
Old 10-15-2013, 05:27 AM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
Well you don't say where the leak is coming from or provide a picture so how can we help?
You didn't mention oil filter housing gasket, check that.
Old 10-15-2013, 05:40 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by Vincenteveraert View Post
BMW 335 ci 2007
A pain in the neck
Any idea
Idea: Tell us where the leak is
Idea: Transmission didn't go in like it came out - you have a rattle now
Idea: Pics or it didn't happen
Idea: Do you say all the above was leaking?
Old 10-15-2013, 06:53 AM
there is no leak to te Housing, is it possible that the Turbos causes that problem, it seam that we have to much pressure in the oil pan ??
Old 10-15-2013, 07:13 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
dude - did you miss the questions above?
permanent oil liak
