Old 10-15-2013, 06:49 AM
Deerfield87 Deerfield87 is offline
Mein Auto: 2005 645ci
Any idea what could be causing oil loss?
I have had my car for several years now with no major issues. It has 63K on it and I have performed standard maintenance regularly - changing oil every 8K or so.
Within last year, oil light has come on a few times and I have noticed my oil reservoir down 1-3 quarts.
There is no visible leakage or any spotting on garage ground, etc.
I assume I am burning oil some how as I have noticed several times after idling at a light, I see a big cloud of blue smoke emit from the exhaust when I accelerate out. Again, only occasionally - I assume this is oil.
Thanks for any assistance or thoughts.
Old 10-15-2013, 08:34 AM
ttuite ttuite is offline
Mein Auto: 650I cabrio
One to three quarts is a LOT of oil to burn through the engine. Is your back bumper coated in oil?
Old 10-15-2013, 09:10 AM
yeah - No physical manifestations at all (other than chrome tailpipes a little darker on the inside from occasional smoke)
Old 10-15-2013, 09:23 AM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
You definitely have a valve stem seal issue that is causing oil to leak. This is a very expensive repair. I hope you have an extended warranty.
Once a 6'er, always a 6'er.
Old 10-15-2013, 06:02 PM
HerbP HerbP is online now
It possibly sounds like you could be having some valve seal problems. 1 more item to check would be the CCV diaphragms. These will only run around 50.00 for both, & it takes 30 minutes to install. Check the DIY section for more info!
Good Luck!
Old 10-16-2013, 06:40 AM
Thanks guys - lets hope it is the latter and not the former - over 8 year old car with 60K on it - warranties are long gone.
Old 10-16-2013, 07:23 AM
RooK77 RooK77 is offline
Mein Auto: 645i
Best of luck, keep us posted.
Old 10-16-2013, 07:49 AM
tampamark tampamark is offline
Mein Auto: 650 Sold - '12 Jaguar XK
I don't think aftermarket warranties would cover valve-stem seals anyway. I haven't read them all but I have seen enough of them!
Typically anything with the word "seal" in it is excluded from coverage since they are considered wear items.
Good luck.
Old 10-16-2013, 01:42 PM
bigscore bigscore is offline
Mein Auto: 06 650i
Not that far a drive from Maryland......
http://www.bimmerfest.com/forums/sho...d.php?t=693230
No car is quite like a BMW....
Old 10-17-2013, 07:22 AM
Very helpful - thank you.
