USB Problem? - Bimmerfest - BMW Forums
Old 10-16-2013, 07:08 AM
davedrass davedrass is offline
Mein Auto: 2011 128i vert
Question USB Problem?
I got a new to me 2011 128i vert.
I plugged in my iPhone 5 with the standard, Apple issued, lightening to USB connector that came with the phone. The phone knows it was connected because it asked me to trust the computer. I said yes trust. Also the phone is charging.
When I click on audio it just says "insert" under the USB part of the menu. No iDrive, just standard.
What am I doing wrong?
Old 10-16-2013, 10:47 AM
Dealer is saying I need a special "Y cable". Make sense? Aftermarket?
Old 10-16-2013, 10:55 AM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
USB Problem?
Dunno. My 09 E92 needs a Y cable to connect my 4S. Not sure exactly when it worked without one. I had an '11 E90 for a while, and IIRC it also needed a Y cable.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 10-16-2013, 11:21 AM
rmjames007 rmjames007 is offline
Mein Auto: 2009 135i
I think that one you need the y Cable and then a 30Pin lighening adapter
Go on ebay. and get the cable for about 25-35 bucks not the cheap one.
Old 12-22-2013, 10:18 PM
Braudham Braudham is offline
Mein Auto: Mazda6
I just got a 2011 128i last week and am having the same issues. I've discovered that I have the base radio which is missing the component that will let you play strictly through the USB. I have to use the Y cable and the audio quality is just awful. I don't understand how a 2011 could have USB but not support the iPhone.
Old 12-23-2013, 02:27 PM
Smoochie Smoochie is offline
Mein Auto: 2011 BMW 135i
Braudham, Same here. I haven't tried (or ordered) Y-cable. I did, however use a free program called iTunesExport to create playlist folders and name them. I then installed all of my desired music on the internal hard drive. I am a bit dissapointed I don't have Sirius on this thing. The phone works fine as a bluetoothed phone and imports my contacts fine. It seems it is just missing the bluetooth audio support.
Old 12-23-2013, 02:50 PM
Re: USB Problem?
Again guys i dont know what year you have but the E82 does not have Bluetooth audio
Old 12-23-2013, 03:14 PM
Lol, that makes sense then. Mine is 2011
Old 12-23-2013, 05:19 PM
Mein Auto: Mazda6
Anyone able to play their songs from iPhone using only the USB on the base audio system?
Old 12-23-2013, 05:25 PM
Brake_L8's Avatar
Brake_L8 Brake_L8 is offline
Ambitious But Rubbish
Mein Auto: 97 M3 | 96 328iC
USB Problem?
I just went through this on my 2009. There was a 2012 (IIRC) update that allows iThings to play using the white Apple USB cord. It's the "NBT" iDrive system. We all have the CIC iDrive.
Prior to that, you need the BMW Y-cord and the Apple 30-pin to Lightning adapter. That's my setup and it works very well with excellent sound quality.
The NBT iDrive cars also allow Bluetooth audio streaming. Yes, be jealous.
Fortunately, the car drives so well otherwise that I don't mind the hurdle of figuring this crap out.
- Jake
Now:
11 Ford F-150 FX4 | 97 BMW M3 | 06 BMW M3 Convertible
Then:
87 BMW 325e | 91 BMW 535i | 96 BMW 328i | 95 BMW 325i |95 Mazda Miata | 13 Ford Focus ST | 09 BMW 128i | 00 Pontiac Firebird | 05 GMC Yukon Denali | 96 BMW 328iC
Old 12-23-2013, 05:29 PM
Mein Auto: Mazda6
Lightbulb
Thanks Brake_L8. This is exactly what I was wondering, if there was some sort of firmware update that was available. You mention iDrive. Is this update only for the iDrive units? My system is the stock radio, no iDrive, no navigation.
Old 12-23-2013, 05:31 PM
Brake_L8's Avatar
USB Problem?
It's not a firmware update. I did some reading, and it looks like people can retrofit the NBT iDrive to a CIC iDrive car - at a cost of thousands of dollars.
If you are sans-iDrive, the same Y-cable logic applies. Not sure how you would retrofit but my guess is the cost would remain prohibitive.
- Jake
Now:
Then:
Old 12-24-2013, 08:42 AM
I just ordered the "Y cable" from AMazon. I am hoping it provides the solution. When it arrives in 8-10 weeks from China, I will share my results.
Old 12-25-2013, 05:54 AM
Brake_L8's Avatar
USB Problem?
Fingers crossed for ya! I got lucky and a friend had some extras so I got an official BMW cable. Otherwise, I was looking at the knockoffs.
There is a chip inside the cable that splits the audio and other signals for the car to read. I can't think it's very complex though, so the China cable ought to work just fine.
- Jake
Now:
Then:
Old 01-04-2014, 10:48 AM
I use the y cable from china and it worked well. I eventually got the arm rest dock for a cleaner look. also on ebay.
For BMW gadgets and cables NEVER go to the dealer. unless you have extrea money to blow.
Old 01-08-2014, 12:02 PM
I received the Y cable last night. Tried it and it said something like it didn't recognize the device. So, again, I am without solution. Going to look into this Bluetooth adapter I read about on another post.
Old 01-08-2014, 12:46 PM
So that has to do with your production date of your car. Mine is a 09 with CIC
Sent from my Galaxy Nexus using BimmerApp mobile app
Old 01-08-2014, 12:48 PM
I had this happen with me and eBay. I got the wrong Y cable as well. Check out the correct y cable your dealer has and the part number to make sure you get the right eBay one
128i, usb
