Old 10-16-2013, 03:41 PM
cagui1223's Avatar
cagui1223 cagui1223 is offline
Mein Auto: 2007 BMW X3 3.0si [e83]
07 X3 3.0si Coolant Leak *FIXED*
Mileage: ~103,000
Over the past few months the "low coolant" light has turned on, which never happened before. I'd top it off and after a month it would turn back on. Off I went hunting down the leak... Found it!
It appears it may be leaking from:
  1. Area where the expansion tank sits on the mounting plate
  2. Water pipe connector.
  3. Level sensor
  4. Overflow hose?
Pictures below the vehicle:
This one was taken from the side.
Based on the last picture, this hose goes from the water pipe connector all the way to the thermostat. Should I replacing this hose? Is this the overflow hose?
The diagram from RealOEM.com says the part # is 17123422785. When I plug this into certain sites it says its not compatible with my vehicle...
Parts Ordered:
www.ECSTuning.com
Coolant Expansion Tank
Mfg Part# 17117573781
ECS Part# ES#2091434
Water Pipe Connector
Mfg Part# 17112248409
ECS Part# ES#38012
www.Bavauto.com
Expansion Tank Thermostat
Part # 17 11 1 437362A
Upper Radiator Hose
Part # CHR0186P
Lower Radiator Hose
Part #CHR0187P
Expansion Tank Retaining Clip
Part # 17 13 2 248 252
Fluid Level Sensor
Part # 52041
Didn't order any coolant since I already have some.
Old 10-30-2013, 10:50 AM
cagui1223's Avatar
Hello everyone,
I hadn't updated this since several parts were on back-order. I finally received all the parts and got to work on it this weekend. The job was fairly simple and completed within a matter of about 3 hours. In all I spent about $200.00 on parts.
** I am not a mechanic, just enjoy fixing my own cars and saving money. Proceed at your own risk **
Make sure the engine and its components are cold before you work on this!
Step 1: Begin to drain the coolant. I decided to drain from the water pipe connector (Doesn't matter which one you decide to drain from IMO). It's easy to find the drain plugs since they're BLUE underneath the vehicle, drivers side front (FIG. 1). Be sure to remove the cap off the radiator to allow more fluid out. A little over a gallon of coolant came out.
FIG. 1
Step 2: As the coolant drained I began removing the Air Duct (FIG. 2) and Intake Duct (FIG. 3). These are held down by Torx screws, can't recall the size.
FIG. 2
FIG. 3
For the Air Filter Housing Unit, push the spring clips off, disconnect the MAF(Mass Air Flow) connector and release the clamp holding the Air Filter to the rubber boot (FIG. 4).
FIG. 4
Remove the air filter and now you'll just have the bottom half of the Air Filter Housing unit left. This piece you just need to lightly pull out of the vehicle as there are no screws holding it down.
FIG. 5
Once all these parts have been removed, this is what you're left with (FIG. 6)
FIG. 6
Here are a few things labeled (FIG. 7)
FIG. 7
Green: Expansion Tank
Red: Upper Radiator Hose
Yellow: This is where the Air Filter Housing sits.
Step 3: Remove Upper radiator hose. This hose has 4 different points of entry. Each one has a retaining clip which need to be partially pulled out to remove the hose. Use a flat-head screwdriver or a thin knife for greater ease. Please note the hose will only go in 1-way so "twisting" the hose when pulling doesn't really help. Refer to FIG. 8
FIG. 8
Remove this hose as well (FIG. 9). I'm not sure exactly what this hose is.
FIG. 9
Step 4: Remove the Expansion tank. Now that the hoses have been disconnected, there is only 1 retaining clip holding it onto the radiator mounting bracket. The clip is located directly underneath the expansion tank. It can be reached from above the expansion tank, next to the radiator fan. Refer to FIG. 10.
Pull the expansion tank upwards, just be careful when doing so since the coolant level sensor is also connected below, don't stretch the wire!
RED: Retaining Clip
GREEN: Coolant level sensor
FIG. 10
Here's what it looks like once expansion tank has been removed (FIG. 11).
FIG. 11
Blue Arrow: This is the water-pipe connector. Because of the way it was designed the only way it'll come out is by bringing the whole radiator out. I ultimately decided not to change this piece since it wasn't leaking AND I couldn't remove the radiator fan...
RED Arrow: Inside this large hole goes the transmission thermostat. I would highly recommend replacing this piece. Overtime it became brittle and broke easily when I tried removing it. Since it was in pieces I had to use a flat-head screwdriver to pull the remaining pieces out. When placing the new thermostat, use a bit of downward force until the piece "sinks" into place.
Transmission Thermostat Picture
Name:	Transmission Thermostat.jpg
Step 5: Replace Expansion tank. Insert the new coolant level sensor into the bottom of the expansion tank and work in reverse.
TIPS:
When replacing expansion tank, DO NOT forget to reconnect coolant sensor. Make sure the expansion tank fits snug against the mounting bracket and DO NOT forget to reconnect the retaining clip. Make sure the water-pipe connector is also snug in place, so try to push this piece further in from the bottom.
Each hose needs to be properly seated. Once done so push the retaining clip in place and try pulling on the hose to see if it releases easy. If so, then its not securely in place. Fill with BMW coolant until the "full" point and be sure to use the bleeder screw to burp the system. Check for leaks, all should be well, sit back and enjoy the savings!
Old 10-30-2013, 11:16 AM
jlex jlex is online now
Mein Auto: 2005 X3.0i
Nice write-up.
I replaced my expansion tank about 2 weeks ago. Didn't have a heater hose seated properly with the clip & ended up losing about a gallon when the hose blew off on the road. Good way to fry a head if you're not careful. Never played with the connector/clip mechanism on hoses before so I wasn't paying attention.
My advice to everyone is not to overfill the expansion tank. IMO, these things start leaking because of too much pressure that isn't efficiently released by the pressure relief valve built into the cap. You need to actually siphon some out after the initial filling to get a good reading on the indicator stick. Filling these plastic tanks to the top as you would a typical radiator is a no no...
Old 10-30-2013, 11:21 AM
cagui1223's Avatar
Originally Posted by jlex View Post
Nice write-up.
+1.
I filled it up to the point where the bleeder screw started pouring fluid out. I put the cap back on the expansion tank then opened up the bleeder screw once again and let some fluid pour out to make sure it was not low on fluid or had anymore air trapped inside.
Old 10-30-2013, 12:07 PM
I guess I'm paranoid about too much pressure on these plastic tanks...
Once I had it filled and the air bled out, I suctioned enough out of the tank so the indicator stick wasn't floating at its maximum. The car has got to go thru 2 or 3 heat/cool cycles before the coolant level settles down. Check it each time (cold of course) during each cycle and you'll probably need to add a little coolant. On mine, I'm not letting the stick rise to its maximum... rather, once it starts floating I don't let it max out, but allow it to float between the marks. That way I'm sure its not overfilled or underfilled....
Haven't had a single drop since the repair.
Old 10-30-2013, 12:08 PM
Grabby544 Grabby544 is offline
Account closed at users request
Mein Auto: 2009 X3
Wow! Awesome DIY!!! Definitely a keeper!
Old 10-30-2013, 01:22 PM
Mein Auto: 2004 X3 2.5i
..... On mine, I'm not letting the stick rise to its maximum... rather, once it starts floating I don't let it max out, but allow it to float between the marks. That way I'm sure its not overfilled or underfilled....
+1
A lot of people interpret "Max." as meaning "fill to here".
May not be a big deal with engine oil level, brake fluid level, etc., but with the coolant level in these BMW's there does seem to be evidence that there is not much margin for error.
Depending on cold or warm coolant, and the fact that it is difficult to sight along the top of the expansion tank and judge if the float max. mark is aligned where it should be,
aiming for the safe middle ground is the best plan.
Old 10-30-2013, 02:48 PM
cagui1223's Avatar
Thanks for the kind words Grabby544!
Old 10-30-2013, 02:49 PM
cagui1223's Avatar
Originally Posted by Supercourse View Post
+1
Couldn't agree more Supercourse.
Old 11-02-2013, 09:55 AM
wilreyca wilreyca is offline
Mein Auto: 2001 330XI, 2007 X3
Expansion tank does not want to come out...
Hello,
I have all top hoses disconnected and the clip from the bottom loose, however the expansion tank does not want to come out no matter how many times I have pulled upwards. Any suggestions?
01 330 XI | Green | Black | Cold Package | Premiun Sound |
07 X3 3.0 SI | Black Saphire | Terracotta | NAV | Premiun Package | Cold Package | Xenon |
Old 11-02-2013, 10:40 AM
cagui1223's Avatar
Originally Posted by wilreyca View Post
Hello,
What about completely removing the clip? You also disconnected the side hose?
Can you post up some pictures?
Old 11-02-2013, 10:57 AM
Any suggestions?
Options:
- lever upwards (carefully) with a suitable prying tool on the base of the tank
- use a jack underneath the tank to push it upwards
- remove bolts that attach tank mounting bracket to rad. and take it out with tank attached
Old 11-02-2013, 11:12 AM
Don't pull straight up on it. Rock it from side to side. It'll come up little by little with unnoticeable movement but it'll eventually give way.
Old 11-02-2013, 11:13 AM
cagui1223's Avatar
Wiggle it..
I cant imagine it being seized down so tight. Only thing holding it in place is the clip underneath.
Old 11-02-2013, 03:27 PM
cagui1223's Avatar
Hello,
....the expansion tank does not want to come out....
Any luck yet wilreyca??
Old 11-04-2013, 06:12 AM
Careful, though. Moving these things too much side to side is what I think breaks the plastic housing on the transmission coolant thermostat.
Old 11-04-2013, 07:45 AM
cagui1223's Avatar
I agree that rotating the expansion tank too much when trying to bring it out might make contact with the thermostat therefore breaking it. However, bear in mind the thermostat is fully submerged in coolant and exposed to rapid and constant change in temperature. The plastic it's made of becomes brittle overtime.
My thermostat was intact when I removed the expansion tank. The top cap broke with pressure I applied using my fingers when trying to pull it out.
Old 11-04-2013, 06:44 PM
Hi,
Yes, right after I posted the message, I gave it another copuple of tries and it came out but I broke the thermostat for the transmission. I am kind of grad that it broke because it forced me to removed it and then I realized that bottom part was so brittle that was it was breaking a part. The bad part is that I didn't have a spare one for the X3 and it didn't look like I was going to get one until the end of the week even from the dealer. So, I took apart the broken one and a new one that I had for a e46, I figured out the body of the thermostat is the same for both of them, so I put the inside parts of the old one in the body of the new one. That saved the day and everything seems to be running fine.
BTW... Thanks everybody for the replies and suggestions.
Old 11-05-2013, 06:40 AM
cagui1223's Avatar
Hi,
Thanks for getting back to us!!
I'm glad you were finally able to remove the expansion tank! It sucks the thermostat broke, however, it's a good thing it happened while you could see it rather than once everything was put back together and have to diagnose another problem. Very creative swap to get a working thermostat!
Old 01-28-2017, 07:48 PM
jmedeiros40 jmedeiros40 is offline
Mein Auto: 2008 X3
Thank you!!
I am currently chasing a coolant leak between the bottle and the secondary coolant pump, i will probably be replacing the bottle and this will be a great help.
Old 01-29-2017, 04:37 AM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
Read some of the other threads on the N52 engine. The bleeding procedures for this engine are different. Consider replacing the water pump and thermostat too, but they are not cheap on these cars. 100k replacement is practiced for those running on PReventaive maintenance strategy.
Old 01-30-2017, 05:31 AM
cagui1223's Avatar
Glad I could help! Good luck!
- CA
Old 01-30-2017, 05:34 AM
cagui1223's Avatar
We kept our X3 up until a few months back, sold with 167,000 Mi on the odometer. Fortunately we never had to replace the waterpump. The thermostat was an entirely different story, I replaced it twice.
Regards,
- CA
