The X5 SAV Forum
Old 10-16-2013, 07:09 PM
mfino mfino is offline
Mein Auto: X5 3.5 - former530xi/323i
Replace Door Pulls
Has anyone replaced door pulls on 03 x5? do you need to take the door panel off?
Thanks.
ECIS Intake | Shark Injector | Scorpion Exhaust | PG2 style rims, YOKOHAMA AVS ES100 235/40/18 | Koni Adjustable's | H&R Front Sway | M3 Lip Spoiler | OEM Clears | Hamann Eyelids | M-Technik Front | M-Technik Sides | M-Aero Rear | 50% Tint | M3 Dead Pedal | MOMO Aluminum Pedals | UUC Gauges |Titanium Shadow Painted Trim
Old 10-17-2013, 07:54 AM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
You'd have more response if we can understand the question. Door pulls?
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 10-18-2013, 08:46 PM
The interior handle when you open and close your door, fairly certain they are called door pulls. Mine are scratched and peeling and would love to replace them.
Old 10-19-2013, 08:16 AM
puddinboo puddinboo is offline
Mein Auto: 2003 BMW X5
here this may help you out. is the black rubber stuff peeling off and then its glossy under neath.
Name:	front door pannel exploded view.png
2003 X5 3.0i
Old 10-20-2013, 06:29 PM
that's it, the black piece with the rubber peeling off.
Old 10-20-2013, 08:05 PM
why do you want to replace it? did you try to just removing the rubber and leave the rest glossy black I think it still looks good that way imo
2003 X5 3.0i
Old 10-20-2013, 08:30 PM
if its the handle that has the rubber coating on it you do have to remove the door pannel ,but if its just peeling I would rub the rest of the rubber off and leave it.
2003 X5 3.0i
Old 10-26-2013, 01:00 AM
jazz USMC jazz USMC is offline
Mein Auto: E46, E53
I just had my panel off yesterday and on the above parts breakdown, part # 14, steel bracket holds your "door pull" i think it was a 10mm nut holding it on from the back. watch out for the lil led light plug in when you take the panel off its a short wire, not much wiggle room and breaks off easily. i googled a Youtube vid on door panel removal and watched a few to get the process but none mentioned the led
