Old 10-17-2013, 01:35 AM
Girardian Girardian is offline
Mein Auto: 2012 650 Ci (M Package)
Passenger Restraint / Airbag Warning
2004 645 with 90K+ miles. Passenger restraint / airbag warning light.
Any feedback on the most common problem that this ends up being? I saw info on a recall on some BMWs re: this error message and wear on a pad tied to the monitor, but I don't see that this recall applies to the 6 series.
Will take it to a shop for an inspection, but am interested to know the most likely issue. Any feedback is appreciated.
Old 10-17-2013, 02:52 AM
hugo_za hugo_za is offline
Mein Auto: E65 740i LCI
I had the same on my car. Reprogrammed the modules using INPA and the error has never come back.
Old 10-17-2013, 03:44 PM
Is this something I can have an independent shop do? Or something I would need to buy something and do myself?
Old 10-17-2013, 05:24 PM
HerbP HerbP is offline
A dead cell in a battery can trigger this fault, I would never had believed it! Diagnostics would help? I had this happen on my 750. The seat pad replacement sensor is around a 1k replacement cost!
Good Luck!
Old 10-17-2013, 09:47 PM
As HerbP mentioned, the battery could very well be the culprit since these cars love to throw phantom errors. Have the battery tested first. If it checks out, most any independent shop worth their salt should be able to reprogram the seat modules. I cannot recall exactly what I did, but I almost think it had something to do with the kind of sensor the control unit was expecting VS the one installed. I have attached my coded tracefiles to this mail, so if you do find someone to help then they will know exactly what to do with them.
Old 10-17-2013, 10:22 PM
greco2000's Avatar
greco2000 greco2000 is offline
Mein Auto: 2008 650i LCI
I had the exact same problem. There is a sensor in the seat belt Buckle and the unit will need to be replaced. Had mine covered by CPO
2012 BMW M6 CONVERTIBLE
Old 11-04-2013, 02:44 PM
Angel2 Angel2 is offline
Mein Auto: 2006 650i Conv
hi can you tell me how did u solve this problem ??
my 2006 650i conv has the same problem!
thanks
Old 12-06-2013, 05:06 PM
I have not yet solved this problem -- I will be having an indi shop look at it after the holidays.
Old 12-06-2013, 06:35 PM
sentrex sentrex is offline
Mein Auto: 645ci convertible 2004
having the same error since i've been working on trunk issue on mine i'm waiting for the module then i will see if those go away i am testing my battery as well since the car wont start
Old 12-06-2013, 06:37 PM
i still have the problem
let me know how you solve it
thanks
Old 01-18-2014, 01:39 PM
Michael201193 Michael201193 is offline
Mein Auto: 2007 550i
I'm having the same issue. a quick way to find out some mroe info that i did last nigh is to have a passenger ride in the car without a seat belt. If it chimes telling your passenger to put on a seat belt; the sensor works. if it stops when they put on their seat belt, its not the seat belt sensor.
Old 01-18-2014, 02:55 PM
maybellineo maybellineo is offline
Mein Auto: 2005 645 Coupe
My sensor works so what can this be. Someone above said they reprogrammed the modules. Now I see he said reprogrammed the seat modules. Does that mean the seat preferences? Where you want you seats?
what the heck does that mean?
Maybellineo
