Old 10-17-2013, 08:50 AM
Dan831344 Dan831344 is offline
Mein Auto: 335 Idrive
2009 335i xdrive software`
hey guys so i got a 2009 335 xdrive coupe. i had a newer bmw 2012 and i had the option to update my software with out bringing it to bmw... from what i saw prior to 2010 you need to bring it down to bmw... is there any way around this? like can i put it on a cd and install to the hard drive? also i want to update my nav is there a CD i can get to update it?
Danny
Old 10-17-2013, 10:14 AM
Mein Auto: '06 AW 330xi
What are you trying to update? EGS? DME? etc...
If you have to ask the question, there is no easy way of updating the software. The way people do it outside of the dealership is to upgrade one module at a time. Dealer selects an i level and flashes the whole car to update. You can mess things up very easily if you don't know what you're doing.
The nav maps for a CIC iDrive unit can be found for free online. They are also available for purchase. Be careful who you buy from though. I know the price for CCC iDrive maps are $200. Not sure about the CIC maps.
Old 10-17-2013, 10:33 AM
not sure what the EGS DME is but essentially what i am looking to do is get it so that my iphone 5 is supported in my car. my 12 worked fine so my guess is its software.
what CIC and CCC for the nav? (sorry i am not to familiar with the component terms) how do i know which one i have? i def like the idea of free better.
Thank you so much for you input!
Danny
Old 10-17-2013, 11:05 AM
EGS is the trans module. DME is engine module. You express you wanted to update the car's software but didn't specify what you wanted to update.
CCC is the older DVD based nav in older pre 08 models. CIC is the hard drive based nav found in later models 09+.
Btw I doubt you could do full car updates through the car. It may push small updates for Connected Drive etc, but not full module updates. It would take too long and kill the battery and/or brick the module due to power loss.
In order to get support for iOS 7 on your 5, you'll need a dealer visit and they will need to flash the entire car.
Old 10-17-2013, 12:13 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
You need to go to the coding sites to get solutions.
The answers won't be simple.
bmwcoders.com
or
http://www.e90post.com/forums/forumdisplay.php?f=368
sorry... i just want to update my ipod/iphone port to support ios7 amd update my navi... i guess in simpler terms the only way to do this is to bring it to a BMW dealer..
Danny
Old 10-17-2013, 12:41 PM
Danny
Yes. Ask for map updates first. Normally, the car needs the newest i-level for the dealer to do coding and updating the maps may very well update support in your CIC module for iOS 7 support. So you may kill 2 birds with 1 stone.
Old 10-17-2013, 01:17 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
For the phone, what you want is an update to the Bluetooth support (drivers) in your car, if available. Bluetooth updates can be downloaded and installed by the end user if the car was built with the correct options.
Go to http://bmw.com/update and enter the last seven digits of your VIN. A list of available updates for your car will be returned. If no results are returned, your car either lacks the option(s) necessary to install Bluetooth drivers yourself or no new drivers compatible with your car's firmware have been released since it was built.
Map updates can also be installed by the end user in the hard-drive based (CIC) navigation system. If your nav requires you to have a map DVD in the player at all times, you have the older CCC-based system (and would just need to buy new DVDs). You have an MY2009 so that should be CIC-based. To update the CIC maps, you need the new map database and an FSC (Freischaltcode, lit. "unlock code") specific to your vehicle. Buying the update from a dealer gets you the maps on a USB flash drive plus a sheet of paper with your FSC, for about $200 total (with the FSC being the bulk of the cost).
Installation takes about 45 minutes IIRC (did mine last December or thereabouts, when the maps came out). Instructions are provided with the maps and there are several DIY threads here on Bimmerfest. You should have a strong battery, or a battery tender, to complete the update while not driving, as the ignition needs to be ON the entire time. IIRC you can interrupt the process and it will resume where it left off--for example, allowing you to update the maps over two or more regular commuting trips--but you cannot use the navigation while the update is in progress, even if interrupted.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
software help
