Oil drainage Q - Bimmerfest - BMW Forums
Old 10-17-2013, 06:26 PM
Bigrob126's Avatar
Bigrob126 Bigrob126 is offline
Mein Auto: 2010 328i Coupe Auto
Oil drainage Q
In the pictures I've seen, it seems that the drain plug faces the rear of the car, at the rear of the oil pan. I saw someone raise the front wheels on ramps and do the oil change. Would the drainage be complete in this fashion, with front raised and oil draining toward the rear, or would I be better off having the car level?
Rob
Old 10-17-2013, 06:50 PM
fun2drive's Avatar
BMWCCA 149159
It will drain just fine level and might take just a bit longer. Also not all BMWs drain rear...
Old 10-17-2013, 09:36 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
It doesn't answer your question, but I believe my E92 doesn't drain rearward, but to the right instead, as in towards passenger side at a right angle.
I've only used ramps for this, and my first time I decided to wait a forever and a half. When I proudly shared my little feat of a DIY oil change, a veteran here who has done a million of em said that he typically migh only wait 5 min or so and then finish it up. I decided to follow suit on the next oil change.
