Old 10-18-2013, 02:40 PM
AnJing408 AnJing408 is offline
Mein Auto: 2007 335i
335i with check engine light coolant thermostat
my check engine light came on and I use a obd 2 scanner and it gave me the code P0128(coolant thermostat) Coolant temperature below thermostat regulating temperature. Any idea what's causing this? faulty coolant sensor maybe?
2007 335i coupe/M-aero front lip spoiler/M3 trunk lip spoiler.....SOLD
Old 10-18-2013, 08:24 PM
Mein Auto: '06 AW 330xi
My bet is your tstat has failed and causing your engine to run under operating temperature. It's designed to fail open.
Old 10-18-2013, 08:29 PM
yes I was thinking of that too. Any clue on how much would repair cost?
