Old 10-18-2013, 07:05 PM
530iGuy55 530iGuy55 is offline
Mein Auto: 2002 BMW 530i
HID bulb.
I have a 2002 530i and one HID Bulb blew and my regular headlights aren't good enough according to the police officer that pulled me over. I need a quick fix and I was wondering if I could swap them out for LED lights instead. Or is there somewhere I can go to gets them. Please help.
Old 10-18-2013, 08:20 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
E39 HIDs are superior to anything else available. I'm not aware of any LED-based headlight retrofits.
I suspect your adjusters are broken. That allows the headlights to point down.
Old 10-18-2013, 08:23 PM
HID bulb.
My passenger side HID works. Just not the drivers side
Old 10-18-2013, 10:51 PM
What do you mean? That the passenger side lights up, and the driver's side does not? If so, it could be the ballast. You can swap ballasts side-to-side as a test.
Old 10-19-2013, 05:35 AM
HID bulb.
Yea. Drivers side doesn't. Only the passenger. I heard someone saying something about to computers that control them
Old 10-19-2013, 06:03 AM
caryalon caryalon is offline
Mein Auto: 2002 530i, 2001 325i
It could be a bad bulb, a bad ballast (the little squarish metal box mounted to the back of the headlight), a loose plug/connector, bad wiring, or a bad LCM (lighting control module).
You need to troubleshoot to determine which is causing the problem. Easy things first. Unplug and replug the connectors. Does that solve it? If not, swap the ballasts. Did the problem move to the other side? Check for voltage at the light. Etc.
You should be able to buy D2S xenon bulbs at the dealer or auto parts store, if a bulb is bad.
Old 10-19-2013, 07:58 AM
Edgy36-39's Avatar
Edgy36-39 Edgy36-39 is offline
Constantly Learning
Mein Auto: 2006 M3, 2002 M5
Whoa -- slow down OP. Don't do anything that will make the situation worse.
1. Could just be the bulb. You can purchase here for pretty reasonable prices. www.retrofitsource.com The OEM style bulb in your car is D2S
Yes, HID cost a lot more than bulbs at parts store but also far better and last longer.
Here's a good tutorial on replacement: http://www.bimmerfest.com/forums/sho...highlight=bulb
2. If not bulb, could be ballast as caryalon says.
If you can do this yourself you'll save a lot of $$.
BLUE HEAVEN:
Interlagos Blue 06 M3, Autologic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here.
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Euro rotors, iPod integration. MRegistry listing here.
Old 10-19-2013, 09:30 AM
richking34 richking34 is offline
Mein Auto: BMW 528i Sport
Will the ballast fry the old wiring?
Old 10-19-2013, 06:08 PM
HID bulb.
I know it's just the bulb. It went out after I flicked them on. So all I need is a new bulb. I need to know the min and max brightness it can take. I heard it was somewhere from 6000k to 8000k
Old 10-19-2013, 09:49 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
6000k & 8000k is the color temperature, not the brightness. All color temperatures emit the same number of lumens but remember, the higher the color temperature, the darker the color produced. This progressive darkening of the light with higher color temperatures results in fewer visible lumens on a dark surface. A 8000k bulb will emit roughly 20% less visible light than a 4300k bulb.
http://www.hidlighthouse.com/hid-xenon-lighting/
Old 10-19-2013, 11:59 PM
eparayno's Avatar
eparayno eparayno is offline
Mein Auto: 2001 530i
It could still be the ballast unless you removed the bulb and inspected it. Stock is 4300K
Old 10-20-2013, 08:20 AM
HID bulb.
So stock is 4300k?
Old 10-20-2013, 02:54 PM
Yes. Don't handle the bulb with your bare hands; use clean cotton gloves.
Old 10-21-2013, 10:31 AM
HID bulb.
Would 8000k or 10000k be good for my car or is 1000k to much?
Old 10-24-2013, 08:04 PM
HID bulb.
So my HID that wasn't working finally worked last night. And if course tonight it won't work. And thoughts as to why?
Old 10-24-2013, 08:11 PM
ameiurus ameiurus is offline
Mein Auto: '06 330i
It's a personal preference. Around 6500K will give you the most light but it still looks a teeny bit yellow to me. I perfer 8000K myself because it looks really white and it brings out the road better for my eyes. I've never drove a car with 10000K or higher but I've seen them on the road and to me it starts getting way too blue.
Old 10-24-2013, 08:15 PM
Mein Auto: '06 330i
I had a 740i that I fought that very problem. I narrowed it down to the input to the ballist(sp?). I never did find out why it was dropping. I ended up wiring the ballist input from the other side. Had to live with the dash telling me I had a bad light but at least I had headlights.
Have you checked the voltage going into the ballist to see if you have input?
Old 10-24-2013, 08:30 PM
Fudman's Avatar
Fudman Fudman is offline
It sounds more like the ballast is failing than the bulb since it lit up.
Old 10-25-2013, 12:21 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
Could be the plug to the back of the bulb. Until you do some diagnostics, it is all purely speculation. I had a problem with the plug connection, it was actually melting from resistance. Of course BMW does not sell replacement plugs, only the entire ballast with plug and cable. I bought replacement plug and cable on Ebay...spliced it in, and it has been working great for over three years. Oh, and get two, if that is what you need, the other side failed a month or two later...
540 M-Sport package (Canadian market), factory Bluetooth phone kit, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, H&R 15mm spacers, Bilstein B14 PSS coil overs, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 10-25-2013, 12:36 PM
There is personal preference and there are facts. The facts are the 4300k factory bulb balances the various properties. Higher color temperature reduce lumens (output) and reduce CRI (color rendering index). People like the look of higher color temperature, but they do not actually perform better.
