Transmission issue - Bimmerfest - BMW Forums
Old 10-19-2013, 07:48 AM
Urbanfine Urbanfine is offline
Mein Auto: 2007 BMW 650i
Transmission issue
Hey guys.
I have a 2007 650 cab. It has 95km. Auto. It's seems when it down shifts back from 2nd gear to first gear I get a little kick or hard downshift. I drives great but not sure if that's an indication that the transmission is on its way out or can it be reset at the dealer?? Any suggestions?? Thanks
Old 10-19-2013, 09:00 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
You can reset it yourself. Insert your key, press start button without pressing the brake petal. Car should now be in the "on position", but not running. Press the accelerator down to the floor (you'll feel it click) and hold it for 60 seconds. That's it! Turn the car off and remove the key. Tranny is reset. You may want to have someone check the fluid level as well.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
Old 10-19-2013, 09:21 AM
