Old 10-19-2013, 06:41 PM
Tightmopedman9 Tightmopedman9 is offline
Mein Auto: Volvo 855T
540i M44 MAF internal diameter?
I'm trying to pin down the characteristic flow curve for a Bosch HFM2 MAF sensor in a 3.25" ID housing. The largest housing ever used with a HFM2 sensor was on a 98 540i M44. I'm not too sure on the specifics of what other cars/years it may have been used on (I'm a BMW noob), but I do know the max flow it could measure was around 1040 KG/h (288.9 g/s) and it is 3.5" OD.
I extracted the MAF curve from a stock binary; all I need to know is the internal diameter of the measurement venturi. With that information I can just multiply the curve by the difference in cross sectional areas.
I believe the part numbers are: BMW p/n 13 62 1 702 078; Bosch p/n 0 280 217 800.
Old 10-19-2013, 06:59 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
And, your point is?
Go here, enter the BMW P/N, and the site will tell you where else the housing is used. www.realoem.com
Old 10-19-2013, 11:58 PM
I'm not trying to make a point, I just would like to know the internal diameter of the MAF/AFM/HFM used on a 540i V8.
Old 10-20-2013, 08:00 PM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
Mine is 3.25" ID.
2000 540/6 Slightly tweeked...everywhere
Old 10-21-2013, 10:47 AM
Awesome, thanks for the information. My custom housing is 3.25" so I guess the difference in flow is due to the intake setup.
