Old 10-20-2013, 10:26 AM
Josh P.'s Avatar
Josh P. Josh P. is offline
Bimmerholic
Mein Auto: 2001 530 SP/PP/CWP/Slush
ideas on fixing tearing door trim rubber
Anyone have any suggestions on how to fix this? As you can see I tried using Sugru but after a while it came loose.
Rather not replace this entire strip since it's only about two inches that have torn away.
2001 530 Steel Blue Metallic, purchased Dec 03
SP/PP/CWP/Slushbox (I know I know)
OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads
"Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget
BMW CCA member for 15 years
Old 10-20-2013, 01:41 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Duck tape?
Old 10-20-2013, 01:59 PM
Nfs021's Avatar
Nfs021 Nfs021 is offline
What Speed Limit?
Mein Auto: 2002 540i R.I.P :'(
Re: ideas on fixing tearing door trim rubber
Super weatherstip adhesive?? If I was me though I'd replace it. It's part # 51210402745. It's around between $50-60 depending where you look online. I know it's pricey, but hey it least if you replace it you won't have to worry about it again for a long time.
Old 10-20-2013, 11:09 PM
retiredat44 retiredat44 is offline
retiredat44
Mein Auto: BMW
Lightbulb
until you get new trim don't be embarrassed to put some silicone (dark color?) in it and some dark tape) it will hold a long while and no one will see it unless they have their nose in it.. IMHO
BMW 2001 530i (E39)
No longer own a BMW, sold it.
(Family cars):
2014.5 Toyota Camry Hybrid
Disabled Veteran:
Old 10-21-2013, 03:29 AM
Josh P.'s Avatar
Bimmerholic
Thanks all. I did try duct tape. It also came off. Maybe I will just buy the part. Thanks for the part number!
Old 10-21-2013, 03:49 AM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Hard to tell from your pic exactly what part you need. Better check that p/n, it doesn't look like your pic to me.
Old 10-21-2013, 10:20 AM
rdl rdl is offline
Mein Auto: 530i 2003
Just a thought - sort of a shot in the dark.
If you could find someone with access to a "make your own size" O-ring kit you will find these kits come with a primer and adhesive that can make a durable joint. It might work for your torn strip, assuming the trim strip and O-ring rubber are similar enough. Or try an industrial supply house for primer and adhesive alone for a price check.
You might have to remove the strip for full access to the tear's edges in order to get a good tight fit.
Regards
RDL
