Old 10-20-2013, 03:45 PM
Rawtide Rawtide is offline
Mein Auto: 2000 540i msport
Not engaging in any gear..
I have a 2000 540i msport auto 117k that has been well maintained. I have experienced no gear slipping or grinding. This after I started the vehicle and put the vehicle in reverse to back out of a parking space and proceeded put the car in drive and suddenly I heard and noise come from under the vehicle and I no longer was in any gear. The car wouldn't even engage in park. Its like it was in neutral and wouldn't engage in any gear. I attempted to restart a few times and go through the gears and heard a slight noise coming from I'll assume from the transmission. The engine was running well and no notifications appeared on the info screen on the dash. I just left the vehicle in park and pulled me emergency brake. While running I smelt no bad smells and no pooling of liquids on the pavement or in the engine bay. Any ideas? Thank you in advance..
Old 10-20-2013, 03:59 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Get it to a garage, and have the trans codes read.
Old 10-20-2013, 04:11 PM
Ironically I was taking it in Tuesday morning to get the front arm bushings replaced (the famous 50mph BMW front end shimmy) so hopefully I can get them to move it up a day.I have no intentions of diy it I was more curious if anyone had any ideas to ease my mind to the seriousness of the problem. Thank you for the response..
Old 10-20-2013, 04:28 PM
pleiades pleiades is offline
Mein Auto: '99 5-spd
If for some reason one of the half-shafts had their output flange pop its lockring and slide out slightly from the differential, you'd have your symptoms.
Old 10-20-2013, 04:33 PM
Thanks, sounds like an affordable fix for the mechanic, I hope...
