Old 10-20-2013, 08:28 PM
mcaval10 mcaval10 is offline
Mein Auto: 2008 328i convertibele
Programming key fob
Hello, have just gotten a used 328I convertible and wanted to program the key fob to perform functions differently than they currently are set, mainly wanted to ad a chirp for when I lock the doors, anyway in the owners manual it says to push the "1" button "up" on the Light Switch arm, to find an icon shaped like a key, when I do this I found some icons, calender, time, etc but not one with the key icon, which of course means I cannot change the setting, anyone know why this is happening, I have only one remote, could it be that the other is a "master" and I have only the "slave"? Thanks for any help.
Mark
Old 10-21-2013, 09:32 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Programming key fob
Two things: 1) keep looking through the menus in the computer, they are in there
2) Do you know if your car has an alarm installed? If I'm not mistaken, it won't chirp unless it does.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 10-21-2013, 12:20 PM
Thanks for the info, I sort of figured it out, the car must be running, and apparently I do not have an alarm so unable to get a chirp, but was able to set door locks and lights the way I'd like them. Thanks again
Mark
Old 10-21-2013, 12:36 PM
bocabimmer's Avatar
Programming key fob
Mark
Yeah, forgot about that minor detail too... Glad you got that sorted out.
2014 i3 BEV
Old 10-21-2013, 12:37 PM
TheyCallMeNun's Avatar
TheyCallMeNun TheyCallMeNun is offline
Fest Wrks
Mein Auto: 07 335i coupe
For all coding needs:
http://www.bmwcoding.com/
They are very well versed in all programming matters over there
BMW Owner Since 17
'00 323i
'07 335i coupe
Black Sapphire 6MT
BMS JB+ & DCI
Turbosmart BOV
Old 10-21-2013, 05:41 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Thanks for the info, I sort of figured it out, the car must be running, ...
Ignition must be on, car not necessarily running. When you insert the key the car goes to the "radio readiness" a/k/a "accessory" state. To switch to "on" without starting the car, press the Start/Stop button without depressing the clutch/brake pedal.
Useful if you want to limit unnecessary cold start/stop cycles or just monkey with these settings while in your garage with the door closed.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 10-21-2013, 09:44 PM
Verts4Ever's Avatar
Verts4Ever Verts4Ever is offline
Random Helpbot
Mein Auto: 2011 E93 335i
Mods4Cars makes a product called RemoteKey that can provide lock/unlock chirp functionality, along with several other handy features.
This is the cousin product to the excellent SmartTop module for cabrios that has similar features plus roof control, except it unfortunately does not have the chirp function.
Cheers.
Old 10-22-2013, 09:58 AM
Thanks again for all of the info, all of it is very helpful, I especially like that you can turn on the ignition by not putting foot on brake and pushing the start button, will help a lot.
Old 10-22-2013, 11:13 AM
Mein Auto: '06 AW 330xi
Cheers.
Does this kit come with a speaker? Because the OEM alarm needs a loudspeaker installed in the rear driver's side wheel well. Without, no noise can be made.
Maybe it sounds the horn? That would sound weird...
key fob, key remote, kkey fob, program key, programming, remote
