The X5 SAV Forum
Old 10-20-2013, 08:30 PM
blomshar blomshar is offline
Mein Auto: 03 BMW X5
2003 x5 Dashboard lights stay on all the time.
Please help. 2003 x5 4.4 We are trying to troubleshoot why all the amber interior lights stay on. We removed the ignition switch, and they still stayed on. We unplugged the LCM and they still stayed on. When this trouble first started, the instrument lights started flashing on and off. Then I found that if I turned the brightness down, they would not flash then. After a couple of days I turned the lights back on brighter, and then they were fine. But driving home last night they had something acting odd, like the current was changing, I then tried to change the brightness on them, but the instrument lights stay on full brightness, and the other amber lights can be dialed up or down door handle lights, heater and defrost lights, stereo as well, the lights under the speedo can be dialed down too. These lights will stay on all the time. Checked wires for cracks, everything looks good, wires are not hard and brittle. I tested all the fuses on each side of the fuse, making sure power was going through every one, all good. Any idea of what I would do next?
Old 10-20-2013, 08:39 PM
puddinboo puddinboo is offline
Mein Auto: 2003 BMW X5
did you unhook the battery for a few minutes to reset the computer and hook back up ? might be worth a shot.
2003 X5 3.0i
Old 10-20-2013, 09:04 PM
Just tried it, they are still on. I might add that I did the ignition switch test, by turning it on, then the lights and then the sun visor lights to find disrupted current, seemed fine. But could the switch be bad, or a bad light switch cause it, I unplugged the light switch but it still feeds power to the headlights, so, can it feed power to the instrument cluster as well? I may need to replace both switches, and then see if there is a cure from that. Any other ideas? Thanks
Old 10-20-2013, 09:16 PM
did you try turnning your switch for the headlights to off instead of auto. seems like the dimmer switch is screwed, you could have a couple issues happenning.
2003 X5 3.0i
Old 10-20-2013, 09:47 PM
I did try it in all positions, I took it out and started to take it apart but wasn't sure if it didn't have some springs in it that may go flying, so I reassembled it and slammed it back into position, there was no change.
Old 10-21-2013, 05:08 AM
maybe its your ignition switch ?
2003 X5 3.0i
Old 10-26-2013, 04:36 PM
Replaced ignition switch, and still same problem. Does anybody have any ideas, thanks for your help.
Old 10-26-2013, 05:13 PM
Can bad capacitors in the instrument cluster cause the instrument lights, the radio lights and door handle lights to stay on when the key is out of the ignition?
Old 11-02-2013, 05:50 PM
I found the problem, the phone case/lid wires were melted together at the hinge and shorted out. It caused all the wires to burn and melt together, we were lucky it didn't catch on fire, because none of the fuses blew. It fed a hot lead back into the interior lights, causing them to continuously be lit. What a pain to find, but that is another spot for BMW guys to look at for future problems, along with the hatch wire loom, good luck on your BMW issues.
Old 11-02-2013, 06:32 PM
wheres the phone case/lid located ? thx for the update. this might help other people out. I don`t think I have this with my x5 can`t find one anywhere. dunno
2003 X5 3.0i
Old 11-02-2013, 06:48 PM
phone is in the console lid. We made an appointment in Boise, Id at Peterson bmw for today, luckily I found the culprit, cancelled it, they said it was the instrument cluster or the general module, ended in an easy fix for me, and cheap, just hours of scratching my head,and tearing every panel out, checking wires and trying to test modules and switches.
Old 11-02-2013, 07:47 PM
yeah I don`t have one one less thing to worry about lol
2003 X5 3.0i
Old 03-06-2015, 05:57 AM
Frankito Frankito is offline
Mein Auto: 2005 BMW X5 4.4 Sport
05 BMW X5 and have the same problem where exactly is the phone case lid ? Does my truck have that ?
Old 03-08-2015, 09:31 PM
Phone hatch
Ours is located in the center console box where your elbow rests. It's in the lid right under where your elbow rests. I hope this helps.
Old 03-09-2015, 03:35 AM
The only thing I see in the center console is just the storage and the pen holder. Is it the same for an 05 x5 ?
Old 03-09-2015, 03:36 AM
What would I need to buy to fix it ?
Old 03-09-2015, 11:29 AM
Fix
I will post a picture of where exactly the short is happening later. All you will need is some wire cutters and some electrical tape.
Old 03-09-2015, 11:30 AM
Ok thanks a million
Old 03-09-2015, 03:23 PM
Images
I have to do one at a time. Sorry
Old 03-09-2015, 03:27 PM
Wher the latch comes up is where there are some wires that get wore from opening and closing the hatch continually - even if you don't have the phone option I pictured I would still look inside to see if any wires are frayed - you can take out the box relatively easy - it just sits in there I believe and you should be able to see something.
It's fine, my truck is not equipped with the phone though it's just another storage compartment for me...
Old 03-09-2015, 03:28 PM
Let me know if you need more
Old 03-09-2015, 03:29 PM
Ok thanks again
Old 12-08-2015, 09:49 PM
AV8R4AA AV8R4AA is offline
Mein Auto: 2000 528it 2004 X5 4.4i
Same problem I was having.
I rerouted the wire bundle to a stationary position.
No more problems.
2004 X5 4.4i
I love my BMW 528it
Old 01-07-2016, 06:43 AM
rustee rustee is offline
Mein Auto: 1999 323i
I had the same problem, after some extensive research i came across this post, i dont have a phone on my 2003 x5 but i decided to check the wires in the center console storage, i removed the cover and saw some harness going to where the phone should go, i ynplug that harness and my light finally went out, everything works well now
