03 X5 MID issue (NOT PIXEL RELATED) - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 10-21-2013, 01:13 PM
bimwad bimwad is offline
Mein Auto: '09 750i, '10 X5, '11 RR
I think this has been covered before but I cannot find the relevant posts, hence the repost.
I unplugged the MID to fix the pixels. I plugged it back in and it doesn't work. I tested my MID in another X5 and it works fine but in mine it only works for 1 minute then cuts out all audio. I swapped it with my buddies X5 MID and his doesn't work in my car either. All through this, the display doesn't light up.
I have checked all three fuses (one in glovebox, two in the cargo area) and unplugged/checked/reseated all without any luck.
I have disconnected the battery for 15 minutes to no avail. I checked the battery voltage and it is showing 13.7V (checked via instrument cluster display).
Any other thoughts guys?
TIA
Mohamed
'05 E53 X5 3.0 | Premium | Rear Climate | Xenons | Privacy Glass
'09 F01 750i sport | premium sound | CWP | Rear Wood Shelf | BT Audio
'10 E70 X5 xdrive30i sport | rear shades | rear climate | iPod/USB | Sat Radio | DVD in Motion activated
'13 328i drive | premium | heated| executive | privacy glass |HUD
'14 F10 550i M Sport | premium sound | CWP | Rear Shade | BT Audio |HUD
'16 K1600GTL Exclusiv
Old 10-21-2013, 02:46 PM
puddinboo puddinboo is offline
Mein Auto: 2003 BMW X5
have a close look at the male / female harness going to mid (make sure no pins moved out of place) double check fuses with multi meter
2003 X5 3.0i
Old 10-21-2013, 07:09 PM
Thanks for the feedback. I will take a look at it tomorrow.
TIA
Mohamed
Old 10-25-2013, 06:23 AM
Got it fixed - stored fault code for "no connection to MID". Had the dealer clean it out and reset it at no charge.
TIA
Mohamed
Old 10-25-2013, 03:05 PM
so your saying it threw a fault code which you had to get clearred to get power back to your mid?
2003 X5 3.0i
Old 10-25-2013, 05:51 PM
yes thats' right...
TIA
Mohamed
Old 10-25-2013, 07:18 PM
so when you unplug the mid did you start the x5 after ?, is that what triggered the code fault?
2003 X5 3.0i
Old 10-25-2013, 07:56 PM
Yes that is exactly what happened. I had taken it out to fix the pixels and was trying to check for them when I turned the car on. Lesson learnt...
TIA
Mohamed
Old 10-26-2013, 09:15 AM
bmws are a different beast.
2003 X5 3.0i
