Old 10-22-2013, 05:09 AM
donsbabybeamer donsbabybeamer is offline
Mein Auto: 2014 X1 28I X-line
What coding can be done on the X1?
Here is what I'd to be able to do:
Roll up windows with remote/lock feature (currently only open windows w/ remote unlock)
Fold in mirrors with remote lock activation
Fold out mirrors with remote unlock activation
Keep Eco mode to last setting (on)
When turning on Eco mode not have the ASS turn on
Not to be negative but talking the the dealer is useless. Is there a shop in New Jersey that can do any of these and how much might they charge?
Thanks for any info
Old 10-22-2013, 09:17 AM
Yggdrasil Yggdrasil is offline
Mein Auto: X1 xDrive28i
Hold your finger on the lock button on the handle (possibly while pressing the lock button on key...I don't recall) and windows will shut.
Old 10-22-2013, 10:02 AM
ScottMZ3 ScottMZ3 is offline
Mein Auto: 2014 X1 sDrive28i xLine
I too would like to know what coding options there are! Hopefully someone has a list they can share.
Old 10-22-2013, 01:36 PM
BMW_AUS BMW_AUS is offline
Mein Auto: 2016 i3 REx Tera
a list of what can be done will be great!
Old 10-23-2013, 07:18 AM
edx1's Avatar
edx1 edx1 is offline
Missing German roads
Mein Auto: X1 xDrive35i,Z3 Coupe 3.0
Are you sure about this? I've tried and had no luck as well as my ED delivery specialist said the feature is disabled on US cars.
From the guys at BimCoding.com for e8X/e9X
# are items not available on the X1
? are for items I'm pretty sure aren't for the X1
On another site, it does appear someone has flashed the 35i with the Alpine B3 flash for faster shifting (I'm not sure if the "sport" flash (slightly less aggressive than B3 but more than stock) is possible and there are probably more items below that aren't supported on the e84 that I've missed.
Convenience & Operational Options
***9744; Close windows/sunroof with key fob
***9744; Fold/unfold mirrors with key fob
# ***9744; Open/Close liftgate with key fob/in-cabin button
***9744; Auto unlock doors when engine is stopped
***9744; Auto eject key fob when engine is stopped
***9744; Set wipers to complete cycle when shutting off the car
***9744; Disable headlight washers
***9744; Enable one-touch window operation with door open
***9744; Disable seatbelt butler for driver
iDrive
***9744; Disable iDrive "Accept" screen
***9744; Disable iDrive camera disclaimers
***9744; Add/Remove weatherband radio
? ***9744; 8 preset buttons instead of 6 (uses Mode and AM/FM buttons for CIC)
Gauge Cluster
***9744; Enable digital speedometer in gauge cluster
***9744; Enable real-time MPG
***9744; Enable shift suggestion in 6MT
***9744; Instrument cluster lighting always on
Alerts
***9744; Disable key in ignition chime
Lighting
***9744; Disable corner ambers
***9744; Enable Euro double blink hazards lights
***9744; Disable auto dimming mirrors
? ***9744; Disable cornering lights (E92 or E70)
? ***9744; Angel eyes as day time running lights (E90 3/2007+ build)
Premium Options
***9744; Enable DVD in Motion (Requires CIC idrive or CCC with DVD Changer)
***9744; One touch Blinker Count Change (2, 4, 5, 6, or 7 blinks)
***9744; Fold in mirrors at any speed while car is in motion
***9744; Fold in mirrors immediately when doors are locked
***9744; Remove lighting errors and warnings for aftermarket lights
***9744; Disable seatbelt chime for driver ***9744; Passenger
Retrofit Options
? ***9744; Bluetooth activation (requires 2MULF, antenna, and mic)
***9744; Disable TPMS
***9744; Other retrofit coding
Navigation Updates
***9744; 2014 BMW On-Board Navigation System Update (CIC idrive)
***9744; 2014 BMW DVD Navigation Maps (CCC idrive)
Software Updates
***9744; Alpina B3 Flash for N54/N55 engines (335i/135i)
? ***9744; E9x M3 DME 240E Flash
? ***9744; E9x M3 Euro DCT Flash
Old 10-23-2013, 09:30 AM
Oh! Definitely some options listed there I would like to set. How do we go about getting them set? Will an independent BMW repair shop do it? And how do we get the full code for each option?
Old 10-23-2013, 09:34 AM
100% sure it works on my car. I'll play with it later to figure out which button has to be pressed when.
Old 10-23-2013, 11:17 AM
Wolfex Wolfex is offline
Mein Auto: X1
Works on my car. I use it all the time. It closed all four windows and the moonroof.
Holding the unlock button on the key fob will open all windows.
Old 10-28-2013, 11:00 AM
Mein Auto: X1
Does anybody know anybody in the LA area that can change coding?
Old 10-28-2013, 05:30 PM
dwaynemosley's Avatar
dwaynemosley dwaynemosley is offline
Mein Auto: Lots of different stuff
Try these guys. They've done a lot of work for me on my E92 M3. They can also do X-series cars.
http://bpmsport.com/coding.php
'10 M3 coupe, Space Gray / Black, DCT
'12 X5d Alpine White
'17 911 Carerra S White
'14 X1 M sport 3.5 Alpine White
'91 M5 Jet Black
'01 M3 Alpine White
Old 10-28-2013, 08:58 PM
gcrofton gcrofton is offline
taxpro
Mein Auto: BMW 540iA and X1 xDrive35
If I hold my finger on the lock button on the handle (without pressing anything on key fob) the doors lock, then the windows roll up and finally moonroof closes.
Old 11-03-2013, 04:49 PM
octopump's Avatar
octopump octopump is offline
Brevity = soul of wit
Mein Auto: F10
OP: the last two, I am not sure it can be done. But I will look.
The X1 (E84) is based on the E chassis still (switch to the F chassis is planned for 2016).
I am in Manhattan. Let me know if you guys need help local or remotely (over the internet).
Old 11-04-2013, 08:56 AM
edx1's Avatar
How about for non CA, any way to close all with just the FOB?
