Old 10-23-2013, 11:28 AM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
Plug in puncture repair
Had a puncture repaired with plug in... Took to the shop to remove the plug in with a patch from inside $40
The guy said next time have this plug in replaced with patch within days and don't drive for too long with a plug is as it's not safe at all and can leak anytime
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 10-23-2013, 02:40 PM
Mein Auto: '06 AW 330xi
I've driven on plugged tires for extended periods of time. Yes, a patch is better and safer, but if you use rubber cement with the plug, it will be fine.
You're only concern is if the plug is near the sidewall. If it's toward the center of the tire, you have nothing to worry about.
Old 10-23-2013, 04:10 PM
SilverX3's Avatar
from Local Automobile Associattion
Tyre repairs
Punctures in tubeless tyres must only be repaired by fitting a vulcanized plug or patch from the inside of the tyre. In all cases the tyre must be removed from the rim to check for internal damage. Plugs that are fitted from the outside do not provide a permanent repair. Tyre repairs are only allowed in the tread area and are best performed by a reputable tyre dealer
Job - Captain
MY11.5 X1 Xdrive25i
Old 10-23-2013, 04:15 PM
Banned
Mein Auto: 2007-335 HTC
Tyre repairs
Blah Blah , it was standard practice in the recent past, and if its so frigging dangerous wouldnt our wonderful government ban the use of them,,,,, cause we know they are ALWAYS right
well actually purchasing a new tire would be the best solution if you are going to be picky
if you think that patch adds any additional strength you are kidding yourself
Old 10-23-2013, 06:22 PM
Chop362's Avatar
Chop362 Chop362 is offline
Mein Auto: 2013 335Is
You tell em hondo
Old 10-23-2013, 06:31 PM
SilverX3's Avatar
+1
tell your government
Job - Captain
MY11.5 X1 Xdrive25i
Old 10-23-2013, 07:16 PM
jhockey18aa jhockey18aa is offline
Mein Auto: 328XI
Rode with a plug/patch for aprox 20K miles on the OEM contis. It still had a slow leak, but always checked my tire PSI monthly.
Previous Bimmers
1986 316i (Euro Spec) SOLD
1993 318i (Euro Spec) SOLD
2003 325i US Spec SOLD
2011 328XI US Spec (current grocery get'er)
Other Beemers
2011 BMW S1000RR The Ultimate Superbike
Old 10-24-2013, 02:48 AM
mossman35 mossman35 is offline
Mein Auto: 2016 340 Xdrive Msport
Sure. We also never had seatbelts, airbags, anti lock brakes.
The plug is not the correct fix. Just because it was done that way in the past doesn't mean it is correct. Also, just because you haven't had an issue doesn't make it safe.
What the tire shop told was completely accurate. I question $40. I had mine repaired (the correct way) for $25.
Old 10-24-2013, 03:57 AM
Banned
get a road hazzard program and get a new tire for 40 bucks
Old 10-24-2013, 09:49 AM
R1200 R1200 is offline
Mein Auto: 328XiT and R1200C
I faced this dilemma early on with RFTs and my thinking was that a RFT with a plug is still a RFT. I ran that plugged tire for years, no problem.
Today I carry a plug kit and can of pressurized sealant for this times when I need a roadside repair that will safely let me continue a road trip. I have confidence that a plugged tire is safe.
Don
328XiT Sonora
Old 10-24-2013, 11:03 AM
Well a plug in the thread (not too close to sidewall) is safer on a RFT since the plug can fail and the tire will be fine... for a few miles. Over time the plug is not safe. It will let water in and ruin the tire from the inside. The plug is temporary until it can be fixed from the interior.
I carry a plug kit and conti kit in my car at all times.
I don't understand all the fuss over having it repaired the correct way. You put the plug in, and within a day or two you go to a tire shop and have it fixed correctly for around $30. Really is $30 going to break the bank. So many people arguing over plugs when the real fix is not a huge expense.
Old 10-24-2013, 11:36 AM
SilverX3's Avatar
Agree
Job - Captain
MY11.5 X1 Xdrive25i
Old 10-24-2013, 12:42 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
A standard practice recommended by who? Since there's not one tire manufacturer that recommends it, and the tire retailer's organization (TIA) does not recommend plugs (as well as NHTSA), you're running out of authoritative sources who do recommend the practice...except for the plug manufactures of course.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 10-24-2013, 12:50 PM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
I don't understand the "safety" implications.
A plug fails and can be replaced by another plug. If so desired, tire can be replaced - what's more there?
Old 10-24-2013, 01:17 PM
pointandgo's Avatar
The safety implication is that the tire should be removed from the wheel and inspected for internal damage before repairing. The tire's inner-liner can easily 'flake off' during run-flat operation. Internal inspection is not done with plug type repairs.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 10-24-2013, 01:44 PM
SilverX3's Avatar
Plug in is convenience.... and convenience has compromise
Job - Captain
MY11.5 X1 Xdrive25i
Old 10-24-2013, 03:21 PM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
If a plug fails, you will have a leak, but not an explosive leak or sidewall failure. I think it's less of an actual safety issue (although hard cornering on a low tire is unsafe) than a reliability and convenience issue. I have no problem with a plug for the short term, but I'd have it patched within a few days. There's no reason to continue driving with a question mark around a tire.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
Old 10-24-2013, 07:25 PM
pointandgo's Avatar
Sometimes the compromise isn't so convenient to the shop, installer:
http://www.tirereview.com/Article/85...avoidable.aspx
Installers, shops who don't adhere to widely accepted industry standards don't stand a chance to defend themselves when things go wrong. Small business liability insurance premiums are already very high...and I suspect that most shops prefer to do things the right way.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 10-24-2013, 08:54 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Totally agree with first two sentences! I have ran with plugs in tires until I had to replace them. Before I cut the plug I would make sure it wasn't leaking. As for the sidewall on the runflats, I just had my rears replaced with non run flats and looked at the sidewall from the inside edge after it was off the rim. No wonder they are so stiff. The sidewalls are about 2" thick which would be very difficult to stick any plug through in my opinion. So, if you can plug a RFT, you are probably ok since it would be pretty tough to get through that much reinforced rubber with a hand tool and should be near the normal tread thickness.
Old 10-24-2013, 09:41 PM
pointandgo's Avatar
2" thick? I don't think so.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 10-24-2013, 10:48 PM
sptt144's Avatar
You don't think so?
"[0002] A run-flat tire with a multi-layer sidewall construction (1.75-2.0" thick) obtains an improved set of performances through a more efficient distribution of material thicknesses and material properties throughout the sidewall. This construction enables improved run-flat endurance with the same amount of sidewall material or mass, or alternatively, an acceptable run-flat endurance with significantly less sidewall material or mass..."
Pointandgo??? Hello?
Old 10-25-2013, 04:32 PM
SilverX3's Avatar
Taking this pic at Tire Shop
White area where tire cannot be repaired
Job - Captain
MY11.5 X1 Xdrive25i
Old 10-25-2013, 08:44 PM
pointandgo's Avatar
You don't think so?
Car & Driver cut one open:
http://www.caranddriver.com/features...ecrets-feature
Looks like 1/2"...MAYBE.
Aside from that, do you want to compare your tire engineering credentials to mine?
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 10-25-2013, 09:37 PM
sptt144's Avatar
Pointandgo:
I won't disagree with you and your credentials big guy. So greater than 1/2" is not piossible on a run flat? Do you have something you have published that we can refer to with measurements? Thanks for the educational update.
Old 10-25-2013, 11:45 PM
Norm37 Norm37 is offline
Mein Auto: Chevy half ton pickup
Correct tire repair article (with pictures) from tire rack.
http://www.tirerack.com/tires/tirete....jsp?techid=77
