Old 10-23-2013, 11:58 PM
2rok1986 2rok1986 is offline
Mein Auto: 2009 BMW 328i Sports pkg
Replacing bushing vs Control arm question
I am new to the forum and a new BMW Owner. I know this is a common question and I've done plenty of research. I just want to know what you guys recommend for my specific vehicle.
2009 328i Sports Pckg. 50k miles. Bought vehicle CPO in February of this year with 37K miles.
Had my vehicle looked at and bushings need replacement.
2 questions:
1. Do you recommend going ahead and replacing Control arms instead of just bushings?. The shops I visited stated it was not necessary to replace the control arm since they should last closer to 100k miles.
2. Dealer of course quoted me closer to $650 just for bushing replacement along w alignment.
Indy should quoted me $403 for bushing replacement with alignment, parts, taxes, etc.
Is the indy shop price decent/common for this type of labor?
Thanks in advance
Old 10-24-2013, 12:09 AM
Gig103's Avatar
Gig103 Gig103 is offline
Not a Bimmer driver anymo
Mein Auto: 2014 Tesla P85D
I was quoted $350 for bushing, so $405 with an alignment seems in the ballpark. I can't comment on the rest of your question though, I hope this helps.
Old 10-24-2013, 05:02 AM
Banned
Mein Auto: 2007-335 HTC
so why would the control arms wear out?
Old 10-24-2013, 05:03 AM
Banned
and why have the bushings worn out only after 50K miles would be my main question
Old 10-24-2013, 06:18 AM
B/\/\W's Avatar
B/\/\W B/\/\W is offline
Monacoblau mit beige
Mein Auto: E92 330i Manual
The control arm is metal and can't wear out, however the bushes and ball joints are the things that wear out.
330i SE coupé
Manual - N52K 262hp, 232ft-lb
Old 10-24-2013, 06:21 AM
B/\/\W's Avatar
Is it cold where you live? Cold weather causes rubber to age and it doesn't flex as easily and would wear out quicker. Short runs on cold mornings might do it.
What are the roads like where the car has been driven? A lot of load would exacerbate the wear rate.
330i SE coupé
Old 10-24-2013, 07:02 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by 2rok1986 View Post
2 questions:
We replace control arms with bushings/ball joints preinstalled for ease of maint - preinstalled wear parts reduce the job to tightening a nut, and tightening a bolt, for each arm. It is a monkey simple install.
That said, why not do it yourself? You'll need at least one floor jack + jack stands. Say if interested - there are several DIY picture posts I can recommend.
The alignment following is to bring 3 simple criteria into spec:
  • Thrust Angle
  • Toe
  • Camber
Best done by a pro familiar with BMW's, should cost <$100. BMW will sell you a Kinematic alignment, which is the very best but essentially does above, close to $300.
I am not a fan of replacing BMW ball joints/bushings only. Replace the arms with same preinstalled - yup, I've done that job; have some cred.
Old 10-24-2013, 07:28 AM
fun2drive's Avatar
BMWCCA 149159
Mein Auto: 335 vert/14JGC/ 13Outback
It is impossible to tell if you have worn bushing and ball joints unless you take them off the car.
If your bushing are shot and by the way did you check to see if they are then it is likely your ball joints are too.
I buy worn out set of control arms and press my own ball joints in because I control the supplier of them which Lemforder is first and Meyle HD is second. This is much cheaper and is remove and replace.
You are spending a lot of money to replace just bushings which I assume they are just pressing the old ones off and the new ones on.
Failing the tools and interest to do this yourself spending the extra money and replacing the control arms with new bushings is frankly the way to go. You will be repeating this work again and paying labor again since you can't save the control arm bushings when you replace the control arms with ball joints installed.
Budget constrained just replace the control arm bushings, if you plan to keep this ride past 100K do the whole deal and save a lot of labor and parts in the future since you will not need to do this for a long time.
Choice is yours.
Old 10-24-2013, 10:20 AM
After looking at my vehicle, the indy shop stated the bushing only need to be replaced. But down the road the ball joints may as well. I guess i am being proactive so I can just have it all done now and not have to do it later. Apparently it would only be $100 more in total (parts).
I live in Miami, FL so its a mixture of city and highway roads. I do drive daily and have put about 12k miles since I bought the vehicle this past February. The previous owner was a lease.
I would do it myself but I am a complete noob to working on cars. Just trying to be the most cost effective by having the Pros do it.
I can see myself working on the car myself in the future due to the high costs of labor. Thanks everyone
Old 10-24-2013, 10:40 AM
Banned
if you do it yourself, which I believe you can, I think when you replace the control arms the wheels have to be on the ground or the wheel jacked up to simulate the wheel being in the loaded position, then you would tighten up the control arm bushing to the proper torque plus 90 degrees
Old 10-24-2013, 10:44 AM
Just making sure..The ball joints and bushings come with the Control arm correct?
