Old 10-22-2013, 07:25 PM
jimmy tran jimmy tran is offline
Mein Auto: bmw e92
hi
hi i am a new member i got a bmw e92 2007 but my car got an issuse dsc and dtc driving stability control system,including drive off assistant,and run flat indicator have failed,every body can help me to fix this thanks
Old 10-23-2013, 11:42 PM
Mein Auto: bmw e92
hi everybody
ID:	403833i got an issue with bmw e92 coupe 2007 about DSC & DTC stability control system,including drive off assistant and run flat tyre,so which part i need to replace hydro unit DSC or repair kit control unit DSC
Old 10-24-2013, 11:23 AM
BostonB6's Avatar
BostonB6 BostonB6 is offline
Mein Auto: 2005 E85 Z4 3.0
Jimmy...I don't think anyone is going to be able to make heads or tails out of your post. Can you clarify what your issue is?
Old 10-24-2013, 11:28 AM
TheyCallMeNun's Avatar
TheyCallMeNun TheyCallMeNun is offline
Fest Wrks
Mein Auto: 07 335i coupe
Originally Posted by bostonb6 View Post
jimmy...i don't think anyone is going to be able to make heads or tails out of your post. Can you clarify what your issue is?
+1
BMW Owner Since 17
'00 323i
'07 335i coupe
Black Sapphire 6MT
BMS JB+ & DCI
Turbosmart BOV
Old 10-24-2013, 05:13 PM
Mein Auto: bmw e92
that my issue,just upload a photo,is it hyro unit dsc or repair kit,control unit dsc,thanks every body
Old 10-24-2013, 05:47 PM
Mein Auto: bmw e92
new member need help please
Old 10-24-2013, 07:19 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Whaaaa?
Old 10-24-2013, 07:24 PM
endlessbummer endlessbummer is offline
Mein Auto: 2008 E90 6-speed
Jimmy, are you trying to determine what is causing the 'dummy lights' to go off? Your best bet is to get your hands on an OBDII tool and pull the codes your car is throwing out.
Old 10-24-2013, 10:02 PM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Asking the exact same question again in a new thread will not yield any better results. Try rephrasing your question.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 10-25-2013, 07:28 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Threads merged. To get help from members you need to be more clear about what the problem is you're having. As stated above if your lights are on pulling the codes is your best bet. I might venture a guess of a wheel speed sensor but that is a total guess. When did this start happen, what are the symptoms, did anything happen before the lights came one, etc.
Tim
Old 10-25-2013, 07:33 AM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
It's either a faulty abs sensor or a a bad dsc hydro pump.
Start b pulling fault codes with a BMW specific scan tool. Not some generic one.
Old 10-27-2013, 12:18 AM
RUS777 RUS777 is offline
Mein Auto: 335
Seems like abs sensor
