Old 10-24-2013, 08:44 PM
Mayorchuck Mayorchuck is offline
Mein Auto: '96 740iL
1996 Orient Blue/Tan part out
I bought this car for the Style 42's and maybe even repair. That is going to be cost prohibitive so I will soon be pulling parts. I will be keeping the engine cover, MAF and a good part of the interior wood trim. Engine and transmission are good. Radio (DSP) is not coming on. I believe the head unit is bad. I just put a CD43 in my DD and will be using the head unit from that car to test the parts car. Car has tamper dot from PO having cluster replaced but not coding VIN into it. Looks like on backlight is out and a just a few pixels. I will start in the next week or two and will do it as I have time. If you need something right away, you should probably look somewhere else. I am not doing this to make money, just recover some of what I spent on the car.
Drivers fender and front bumper are trashed. Hood damaged but repairable. Drivers mirror is gone and drivers door has repairable dent. Windows all work properly. Cupholder is just like yours, broken. Seats are worn pretty good. Have just a few pics for now.
Old 10-24-2013, 08:52 PM
ebida3's Avatar
ebida3 ebida3 is offline
Society of the 7's East
Mein Auto: 2001 740iL
If the pass rear-view mirror is good and the mirror has the 'dip' feature I am interested. Also I could use to plastic lugs that anchor the rubber straps in the trunk. There are embedded in the carpet.
Old 10-24-2013, 08:57 PM
I will take a look at the mirror itself. I know it dips when you put it in reverse if that is what you are referring to. I will put a list together and check some stuff Sunday. Won't have time to pull parts but can take some pics and check on any requests.
Old 10-24-2013, 11:18 PM
SDG32 SDG32 is offline
Mein Auto: 1996 740il
I would be interested in the rims/tires. What size are they?
Old 10-25-2013, 07:32 PM
They are 18's but I was not planning to sell those unless I come across some cheap Mpars before spring. Going to use the weaves thru winter.
Old 10-25-2013, 08:22 PM
ebida3's Avatar
If they go down in reverse then it's a fit for me.
I just need the actual glass. It's removable. There is a small tab underneath the glass that you have to move, either to the left or right, with a small blade screwdriver and it turns the locking ring that holds the glass on.
Old 10-25-2013, 08:27 PM
I have removed them before. Will check it out and let you know..
Old 10-27-2013, 06:37 AM
Skippy33 Skippy33 is offline
Mein Auto: 740 I
I am interested in the grill covers and rear bumper.
Old 10-27-2013, 09:10 AM
Unless the deal fall thru, the rear bumper is sold. He is just buying the bumper cover so if you need the rail/shocks for it, let me know. If you mean the kidney grills, they are both lose. I will look to see if the clips on the grill are bad or if it's the backside tabs. If you have good inners, you may be able to use these.
Old 10-31-2013, 06:41 AM
Mein Auto: 740 I
Sorry for the delay, I was at a buddies wedding in Key Largo. If the grill covers are good ill take them. I have stock wheels if you wat to trade for yours. I have to do an invertory on my car. Save the grill covers and Ill get back to you today or tomorrow with a list.
Skip
Old 10-31-2013, 08:40 AM
No hurry. Weather has had me behind on other projects. Will be starting on the car a little this weekend. One of the grills is a cheap aftermarket with broken rails.
Old 10-31-2013, 05:18 PM
Hartge 635 Hartge 635 is offline
Mein Auto: 740il/X5/635csi Euro
How are the grills?
Old 10-31-2013, 05:23 PM
Skippy has dibs on the grills, but one of them is broken. Really cheap. I will be taking pictures this weekend of various parts.
Old 10-31-2013, 05:39 PM
Old 10-31-2013, 05:41 PM
What about cluster
Old 11-05-2013, 05:54 PM
Originally Posted by Hartge 635 View Post
What about cluster
Sorry, did not get a notification email on this. The cluster obviously has a backlight bulb out. You can see in the picture that there is a pixel out in the 'H' of 'LIGHTS'. The car goes thru a series of warning because of the damage to the car and it appears those 5, or however many there are top to bottom, are the only ones that don't work. I have not pulled the cluster out to see if the IKE module is a separate piece or not. PO said the cluster was replaced due to bad pixels but since there is a tamper dot, they either purchased a used one or got it from the dealer and did not want to pay for the VIN coding. I believe it was a used on as reading the mileage from the LCM, it shows the car has 147k miles on it. When there is a discrepancy between modules, cluster always shows the higher mileage.
Old 11-05-2013, 05:56 PM
Have not forgot about this. I took a few interior pics but forgot to take a pic of the glass. Having trouble with getting wheels off so got tied up with that. Won't work on it tonight but may go down and take a pic for you.
Edit: Not perfect but not bad.
Old 11-05-2013, 07:14 PM
****Per request, added some interior pics. Seat are worn. Grime on drivers door and glove box area****
Old 11-07-2013, 07:58 AM
umewes umewes is offline
Is the sliding shade for sun roof available? Headliner is separating on mine. It should fit a 2001 right? Please advise. Thanks
2001 740i
Old 11-07-2013, 11:34 AM
BMW740i2000 BMW740i2000 is offline
Mein Auto: 740i
PM sent~
Thanks~
Old 11-07-2013, 06:47 PM
Sunroof spoken for. Some parts may take awhile to remove so will get back with you if they source the part elsewhere.
Old 11-08-2013, 05:27 AM
Thanks.
2001 740i
Old 11-08-2013, 08:44 AM
jferzacca95 jferzacca95 is offline
Mein Auto: 1998 750IL
Do you have double pane glass or single pane glass in the windows? I have a '98 750IL and want to start replacing the glass because of lamination problems. How about your washer pumps, are they operational and what type of electrical connector is it? Please send pictures of it. Thanks!
Old 11-08-2013, 10:56 AM
BigRed87 BigRed87 is offline
Mein Auto: 97 740i
i am interested in the lcm and the module from the driver seat are they still good and do you know if they would work in a 97 740i? and how much do you want for them?
Old 11-08-2013, 11:03 AM
Mein Auto: 97 740i
also i am interested in the cats if they are still good and available?
HTML code is Off
